Thread started 05 Nov 2008 (Wednesday) 13:40
Which Frame Enhances The Image?
LeuceDeuce
Nov 05, 2008 13:40 |  #1
Which Mat/Frame combo?
my website: Light & Shadow (external link)
my flickr (external link)
0ozma
Nov 05, 2008 14:09 |  #2
I like the black one
Canon 50D | Canon EF 50mm F/1.4 | Canon 70-200mm F/4 L | Canon 17-55mm F/2.8 |
Save $5 on a new Zenfolio account using this code:
3P6-72F-UB8
hurley1718
Nov 05, 2008 14:11 |  #3
I like the white one. Since you have a lot of dark tones on the left hand side of the image it doesn't compete as much and makes the image stand out more.
Nice image by the way.
"I'm not immature, my default age limit is set to low."- someone in my head told me to write that.
FlyingPhotog
Cream of the "Prop"
Nov 05, 2008 14:12 |  #4
White works nicely IMO...
Jay
acchildress
Nov 05, 2008 14:15 |  #5
The black one, brings out more detail in the blacks to the left.
Come be a big fish in a little pond, help build
theanswerjar.com  (external link)
L.Morey
Nov 05, 2008 14:23 |  #6
Whit one
7d gripped,40d gripped,G9,17-40f4L, 24-70f2.8 L, 70-200f2.8 mkll L, 100-400 f4.5-5.6 L, 50f1.4 , 85f1.8 , Sigma 24-70f2.8
Sigma 150-500 , Sigma 18-200f4-6.3 , Canon Ste2 , Canon
580mki , Canon 580mkllx2
http://lwmorey.zenfoli​o.com/ (external link)
LeuceDeuce
Nov 05, 2008 14:26 as a reply to  @ acchildress's post |  #7
The original image was not this dark, and I had intended to frame it using a black mat.
The print I got back from the lab is much darker than the image I sent in. I adjusted the gamma on the digital file to closer match the final print (0.70!).
My monitor is calibrated to the lab's specs, and I always set my tonal range from 5-248 before sending an image to print to compensate for the shadows and highlights.
Lab says they're using new paper from Kodak that better preserves the highlights, but blocks up the shadows (nice to know this beforehand, but what can you do?).
A lot of the shadow area still ended up being completely blocked up so now I think the black mat is overpowering the image, and closing it in.
Not saying I'm picky, but I'm picky :D
Cdeming
"īt" didn't fall off
Nov 05, 2008 15:40 |  #8
I like the black better. For some reason the colors pop more than on the white.
;) Chrissy
Gear - 5D, Canon 85mm 1.2L, 50mm 1.2L, 24mm 1.2L, Speedlite 580EXII Website (external link) l Blog  (external link)l Facebook (external link) (friend me) l Fanpage (external link) (like me :))
Currently Reading (again): Harry Potter and the Half-Blood Prince
LeuceDeuce
Nov 05, 2008 16:02 as a reply to  @ Cdeming's post |  #9
Thanks for the help guys n gals.
I was hoping that it was going to be a clear cut situation that I was missing, but alas I'll have to make my own decision.
I'm going with white. I just think the black is going to be way too overbearing, and won't allow the image to stand on its own.
photoguy6405
Nov 05, 2008 17:25 |  #10
You've already chosen, but I like the black, also. To me it brings out the colors better.
Website: Iowa Landscape Photography (external link) | Blog (external link) | Gear List & Feedback
Equipment For Sale: Canon PowerShot A95
Cdeming
Nov 05, 2008 18:23 |  #11
I think I would like to add that it's a beautiful shot...I didn't say that before. :)
;) Chrissy
vpnd
Nov 05, 2008 19:02 |  #12
first one...can't go wrong with black frame and white matting.
Canon "Snappy".... Thanks Mom and Dad!
"I don't like to play dress up, or pet my gear. I like to shoot stuff and then print it and put it on my wall."
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 05, 2008 23:10 as a reply to  @ vpnd's post |  #13
I have not read any of the comments yet because I did not want to get confused by logic and facts before giving my opinion. At first glance, I had to scroll back and forth a couple times to convince myself that I was looking at the same image in both cases -- it is very interesting how the color of the matting can affect the overall appearance.
After some thought, I have reached the following conclusions:
  • I do not like the white mat because it forces your visual perception to adopt the mat's white point which may not necessarily be the same as the image's white point. Personally, I feel that white mats should be reserved for special cases such as B&W images -- and even then, you need to be careful about the selection of white to make certain that it has the same white as the photo paper.
  • I do not particularly like the dark gray mat either because it seems to be too wide for the image and in too stark a contrast with the vibrant colors of the sunset. It also has the effect of making the overall appearance of the image seem darker than it actually is.
  • So what would I like? This is just a guess, but I think that a neutral gray mat that is a bit lighter than middle gray. I tried a gray value of A0A0A0 and thought that the results looked satisfactory. It manages to set the image off without swamping it with too much light or darkness.
Interestingly, I also tried a terra cotta mat color which picked up a lot of the sunset colors, but I would hesitate to seriously consider it without getting some feedback on how others perceived it.
Now, I need to go back and see what everyone else said.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
OdiN1701
Nov 05, 2008 23:18 |  #14
Try a different color - white is too bright for this photo and on the black you are losing your edge in the lower left. You never want the edge of your photo to blend into your mat.
Try a color that appears in your sunset somewhere.
Or try a dark grey. You won't lose your edge and your colors may still be brought out.
SAY NO TO SPEC WORK! (external link)
40D w/ Grip |
20D w/ Grip | 10D
10-22mm|17-40f/4L|24-105f/4LIS|70-200f/2.8LIS|50f/1.4|100f/2.8Macro
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 05, 2008 23:32 |  #15
OdiN1701 wrote in post #6632710 (external link)
I found the terra cotta color about 3/4 inch to the right of the sun (I am still trying to drum up support for terra cotta  :oops:).
I am seeing the dark mat as being a very dark gray (actually with a very slight mauve tint if the luminosity is increased). I get the impression that everyone else is seeing black -- is this correct? The actual color value is R=18, G=16, and B=17.
1,291 views & 0 likes for this thread, 16 members have posted to it.
2892 guests, 134 members online
