Thread started 05 Nov 2008 (Wednesday) 22:03
White Balance Lens Cap
AzMandella
Nov 05, 2008 22:03 |  #1
Who uses one and how do you like it and what brand?
Canon 5D Mk III , 1Ds MkII , 20D , 16-35 f2.8L , 24-70 f2.8L , 70-200 f4L IS , 28-135 IS , 85 1.8 , 2-600 EX II , 2-580EXII , 1-580 EX.
Headshotzx
Nov 06, 2008 01:29 |  #2
Mennon WB cap for cheap, and it does the job pretty well.
However, sometimes it can be a very little bit warm.
Zexun | Flickr (external link) | YouTube (external link) |
ben_r_
-POTN's Three legged Support-
Nov 06, 2008 08:14 |  #3
When you say white balance lens cap youre referring to something like an ExpoDisc right? Just for attempting to properly set white balance? If thats all youre looking to do I'd suggest depending on your subject using a grey card instead. If your shooting something where a grey card simply cant be used like landscapes or something, just shoot raw and fix it later in post processing.
SnapLocally.com
Nov 06, 2008 08:21 |  #4
Caps = Overpriced gimmicks
Try using a coffee filter. Put your lens on manual focus, aperture priority, cover your lens with the filter, aim it at the light source, and there it is- your source image for CWB.
www.SnapLocally.com (external link)
AzMandella
Nov 06, 2008 17:51 |  #5
ben_r_ wrote in post #6634176 (external link)
I always shoot raw. But I have found that using a white sheet of paper works good also. I did a test where I shot using the same aperature and SS using the same studio lighting. I used a grey card,white sheet of paper, and auto white ballance. When editing I would just correct with the auto adjust white balance to see how much change in the histogram occured and the white sheet of paper was the best. The histogram only moved minimally as where the grey card was next and the auto white balance was the worst. I try to expose the best I can to reduce post procesing. I feel that the best pics are the ones that were exposed properly rather than manipulated. That's why I was wondering if anyone had used an ExpoDisc or similar to set white balance.
cutaway
Nov 06, 2008 18:56 |  #6
I use a WhiBal. (http://www.rawworkflow​.com/whibal/ (external link)). I think the main thing for me is that it is supposed to be spectrally balanced and remains consistent. It's also sturdy and easily stowed away.
tgara
Nov 06, 2008 20:51 as a reply to  @ cutaway's post |  #7
I use an Expo Disc, particularly when shooting indoors with tungsten lights or in a mixed lighting situation. It works great -- somebody should get a Nobel Prize for inventing this thing. The Expodisc is helpful because it integrates light sources from all angles, just like an incident light meter. Slight variations of angle won't affect the color balance as it will with a card.
EOS 5D Mark III
EOS Rebel SL1
Full Gear List
Okami
Nov 07, 2008 18:55 |  #8
going to check out the whibal, expos seem pretty expensive
Headcase650
Joined Jun 2004
Nov 08, 2008 10:33 |  #9
Any neutral translucent plastic over the lens will do the same thing. When the expodisc was first introduced the popular alternative was a lid from a pringles tube. They have sense went with a clear plastic but I think you get the idea. I think Crisco shortning lids could probably be used.
60D, Canon 18-135 IS, Sigma 10-20 hsm, 24-70 2.8 hsm, 70-200 2.8 hsm, 430EX II, and all the other stuff that goes along with it.
seanv
Nov 08, 2008 11:22 |  #10
I have a WhiBal card, and maybe I'm missing something, but I wouldn't bother to replace it if it vaporized. I shoot mostly in a controlled studio setting, and when I sample different areas of the card (same shot,) I get a range of different readings. Not exactly what I was hoping for from a 40 dollar piece of plastic.
Sean
ean@musicalpeace.com (external link)
MagikTrik
Nov 12, 2008 16:24 |  #11
seanv wrote in post #6647885 (external link)
Are you sure you placing it correctly, like so the light hits it evenly? I mean I'm certainly not implying your not smart enough, but I've owned a total of 5 WhiBal cards & have never had a problem with anything, especially difference from spot-to-spot on a single card & from what I hear they do have fairly strict quality control in factory, trashing batches that are a certain percentage of difference from card to card. Is it a name brand WhiBal card? Do you maybe carry it in your pocket or out of it's little case in your bag (I know the color goes all the way through but if there is a deep enough gouge it could make a shadow I suppose)?
Of course I believe you, I don't mean to sound like that, I'd just like to figure out why your having that problem, know what I mean?
My Gear List
Zenfolio (external link)
DeviantArt (external link)
When critiquing my images please be as harsh as you feel is necessary.
gkas
Joined Nov 2002
Nov 12, 2008 23:23 |  #12
MagikTrik wrote in post #6674596 (external link)
I agree. As long as the angle is correct, I've never had a problem with mine.
Gerry Kaslowski
gkas@socal.rr.com (external link)
Gerry's Pics http://MikeKazPhotogra​phy.com/Gerry/ (external link)
2005GLI
Nov 13, 2008 19:40 |  #13
i use the expodisc on occaision and its pretty good. It helps me the best in overcast days.
|Canon 80D|40D backup|24-105 F4/L|Sigma 70-200 F/2.8|Sigma 150-500 C|
|Tokina 12-24|Sigma 8mm Fisheye|
Travelller
May 27, 2010 08:06 |  #14
Yes, old thread, I know, but that's what the Search Engine spit out first, sooo...
I recently saw a shot of a Photojojo White Balance Lens cap (external link) from a member and I have to say I like the idea. However, at $65 plus [Int'l] shipping, I'd like to hear a first-hand account from member(s) who use it, please... .
I also saw the filter types but I'd just assume not have to screw on anything as I want to be able to change my filters unhindered. I'm also not a big fan of the Pringles-lid solutions... (who's to say they are truly neutral?)
Traveller
my photo gear (external link)
Mike ­ K
Joined Apr 2001
May 27, 2010 10:10 |  #15
Here is a survey/review of available on lens white balance products.
http://www.ppmag.com …arison-white-balan-1.html (external link)
Cupcake liners work pretty well, and they are the right price!
Mike K
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
15,108 views & 0 likes for this thread, 26 members have posted to it.
2753 guests, 161 members online
