Thread started 25 Feb 2005 (Friday) 22:42
peanut slave fires once
sagebrush
Joined Dec 2001
Feb 25, 2005 22:42 |  #1
Hello,
I have a WEIN Peanut slave connected to a 550EX flash. It triggers fine the first time but after that the 550EX seems locked as it won't fire with the peanut or manually. I also can't change mode or any other setting on the 550. If I cycle power or remove and reinstall the peanut it works fine again for one shot.
Does anyone else use this sort of setup with success?
Sage
scottbergerphoto
Joined Jun 2003
Feb 26, 2005 07:13 |  #2
Peanut slaves, as you have just found out, won't work on Canon EX flashes. They aren't able to recycle the flash. You have to manually turn the flash off and then back on each time. You can use a set of Pocket Wizards to fire them, but then you need a set of PW's and a Hot Shoe adapter for them that you can get at www.paramountcords.com (external link) .
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
sagebrush
Joined Dec 2001
Feb 26, 2005 16:19 |  #3
Scott,
Thanks for your rely.
Sagabrush
3,757 views & 0 likes for this thread, 2 members have posted to it.
1209 guests, 131 members online
