Thread started 07 Nov 2008 (Friday) 05:05
Getting pin sharp birds? Frustrated!!
Vulcan58
Nov 07, 2008 05:05 |  #1
I don't know whether it's me or the camera, but trying out the new 500L on birds in the garden, I just cannot get a pin sharp picture.
These are 1250/sec F4, ISO 400, AF mode -Al focus, centre focus (aimed at birds head) but each time I try I'm still getting slightly soft images.
Used on tripod, locked off as well & the IS turned off.
Tried the same with 'one shot' af and get the same.
I'm pretty sure the 500 is OK as this keeps happening with my 100 - 400 as well, yet the camera produces good crisp pics with all the smaller lenses (17 - 85, 24 - 105).
So where am I going wrong here please?
original
IMAGE: http://i133.photobucket.com/albums/q54/maypole_photos/feeder.jpg
100% crop
IMAGE: http://i133.photobucket.com/albums/q54/maypole_photos/feedercrop.jpg
TATER64
Nov 07, 2008 05:33 |  #2
It looks like the focus is on the leaves and branches in the top 3rd of the pic.
eg can see the veins on the leaf at the very top left,
a crop in the area would probably confirm this
Canon 40D,Wigma 10-20mm,Canon 50mm F1.8 MkII, Canon EF-S 18-55MM IS,Canon 24-105mmL IS USM,Canon 70-200mm L IS F/4, Hoya CPL,Lowepro sling shot 200 back pack,Naneu Pro UrbanGear U60 Backpack
Spud
Flickr (external link) Photos
Vulcan58
Nov 07, 2008 06:21 |  #3
Hi Tater
Here's a crop of the leaves
IMAGE: http://i133.photobucket.com/albums/q54/maypole_photos/feederleavescrop.jpg
Another one (no birds) 1250/sec F4, ISO 200, al focus, all AF points selected & again in AV mode.
As you can see, the focus is very hit & miss as none of the lower pic seems very sharp at all.
IMAGE: http://i133.photobucket.com/albums/q54/maypole_photos/feederempty.jpg
crop
IMAGE: http://i133.photobucket.com/albums/q54/maypole_photos/feederemptycrop.jpg
The feeder is about 20ft from the camera.
Here's a robin taken just over the min focus distance.
IMAGE: http://i133.photobucket.com/albums/q54/maypole_photos/robin2.jpg
EOS_JD
Nov 07, 2008 06:27 |  #4
You might find that focusing with a 30D is more difficult with only 9AF points than with say a 1D with its 45.
What af point are you using?
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
Vulcan58
Nov 07, 2008 06:39 |  #5
The first pics were using central AF point, then I thought try all 9 for the 2nd pics - which actually look worse.
The AF point was centred on the birds head in the first set, but looking at the crop it appears to be much higher up (somehow I can't get the AF points to show in ZB, otherwise I'd post the pics with the AF)
It does seem odd that I can get some real sharp pics, then on another occasion they just look rubbish.
Keep thinking it's got to be something I'm doing wrong.
I may try and borrow someone elses Canon and compare shot for shot with my 30D
5Dmaniac
Nov 07, 2008 06:45 |  #6
I don't think the 30Ds lesser AF points is the issue here - there are many photographers using that combo who take great, tack sharp shots. I think it is your technique, rather than the body or the lens. I had to get used to my 500mm as well - took some time.
Here is my set-up and my technique: Gitzo CF 5 series tripod (very rigid and vibration free), Wimberley head (started out with the side kick, but pretty soon swapped for the full Wimberley), IS on the 500 is always on (either in mode 1 for your type of shots or in mode 2 for birds in flight). My left hand rests on top of the lens when I take pictures.
I use either AI Servo, or single shot AF and I typically shoot in AV mode.
Given that both your long lenses produce soft pictures, it must be your technique or you have the worst of luck and both of them don't focus correctly.
Vulcan58
Nov 07, 2008 07:36 |  #7
I'm also using full wimberley head & Gitzo 3530ls tripod- (rock steady) - It's too heavy for me to hold for very long that's for sure.
Also prefer to use AV mode and normally one shot or al servo with central AF point.
The IS is off, as I'm led to believe it would do so anyway mounted on a tripod.
I guess it's probably me even tho' I'm soft on the shutter button and never 'stab' at it.
Have just taken some more which were much closer to the camera (probably 15 or 16ft max) and will post them on the Birds forum - they seem to have come out OK!!
Thanks for all the replies - we won't learn unless we ask.
hollis_f
Nov 07, 2008 12:10 |  #8
Vulcan58 wrote in post #6640419 (external link)
Aaargh! Try ignoring AI focus. It's supposed to have the advantages of AI Servo and Single-Shot. In fact it seems to combine the disadvantages of the two modes. For the sort of shots you're taking I'd stick with Single-Shot.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 07, 2008 12:22 as a reply to  @ Vulcan58's post |  #9
What was the shooting distance in the first image? If the bird was a significant distance way (like 50 feet for example) then there are two possible factors affecting sharpness:
  • the bird may not be filling enough of the frame to get a sharp image
  • the AF point is actually somewhat larger than the box etched on the focus screen and it tends to pick the point of sharpest contrast and not what is under the red dot
I am still learning to be a decent bird photographer, but have a ways to go, but those who know what they are doing tell me that getting really close is the solution to the problem -- they seem to define "really close" as being less than 15 feet.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
Vulcan58
Nov 07, 2008 15:00 |  #10
Thanks for the reply Bill B.
I was thinking along the lines that the subject may have been too small to reproduce at a decent size when cropped.
Distance to the feeder was about 25 - 30ft away, yet when Itried hand held at about 16ft or so, they've come out reasonably -ish well.
Thinks to self that I must attempt to fill the frame more.
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 07, 2008 15:54 |  #11
Vulcan58 wrote in post #6643405 (external link)
...Thinks to self that I must attempt to fill the frame more.
Yes, I think that is the key. So easy to say, but so difficult to do.
Keith ­ R
Nov 08, 2008 19:01 |  #12
AI Servo, centre AF Point, get closer, keep at it.
gasrocks
Nov 10, 2008 12:40 |  #13
Leave the IS on when using the 500/4 on a tripod.
Vulcan58
Nov 11, 2008 02:42 |  #14
gasrocks wrote in post #6659643 (external link)
That contradicts Canons info - that the IS will be turned off when on a tripod as the circuitry in the lens foot detects the tripod, although power will still be supplied to the IS circuit.
One thing that gets me thinking - if the foot detects a tripod, how come the IS still works with the lens plate attached, using hand held?
hollis_f
Nov 11, 2008 03:08 |  #15
Vulcan58 wrote in post #6664050 (external link)
The foot doesn't detect a tripod. The IS system detects when there is no movement and switches itself off.
7,465 views & 0 likes for this thread, 16 members have posted to it.
916 guests, 109 members online
