Thread started 09 Nov 2008 (Sunday) 09:37
Outdoors and Fill Flash
ocabj
Nov 09, 2008 09:37 |  #1
I recently got the 580 EX II and I'm trying to play around with outdoor fill flash. I always bring my camera with me to shooting matches, so I tried the 580 to see what could be done in daylight.
Here's one example from the other day:
Any comments about the use of fill flash? Is it done completely wrong?
I was about 2-3 yards away from the subject. Sun is at 9 o'clock (the shooter's 6 o'clock) at about 45 degrees.
I had a 28mm f/1.8 prime on the camera and used the high speed sync. I think the shutter was 1/1600 at f/4 and it might have been in Av mode when I took the photo.
Jonathan Ocab - https://www.ocabj.net (external link) - http://jocabphoto.com (external link)
CatchingUp
Nov 09, 2008 09:44 |  #2
Did you have the flash head tilted or directly aimed? Also, what about a defuser, did you have one on?
I certainly don't claim to be an authority on the subject...as I still am toying around with using a fill flash. I normally don't use it unless I'm dealing with harsh shadows from like a baseball cap or other shade maker. Have you got a shot of this without the flash to compare?
What did You think of this shot?
Tony
I use Canon gear...have several bodies and lenses and am quite pleased with them.
"A person's gift will make room for itself."
ocabj
Nov 09, 2008 09:48 |  #3
Direct flash. No diffuser.
I didn't take that photo without flash, but here's photo from another match, same location, at about the same time in the day (similar sun position), without flash.
CatchingUp
Nov 09, 2008 10:27 |  #4
well, given the two to compare, the flash was a plus...a little hot for my own personal taste. I guess being as close as you were, I might have tried tilting the head or defusing it to avoid such a direct hit.
What kind of rifles are those?
Tony
ocabj
Nov 09, 2008 10:59 |  #5
The first is an AR-15 (civilian version of the military M16). The second is an M1 Garand.
Both are "National Match" configured rifles. Basically, gunsmithed/modified to attain maximum accuracy for use in Service Rifle competitions.
myckul
Nov 09, 2008 11:22 |  #6
very nice on the first shot, a diffuser would have given a less harsh light on his face, try to use the flash off of the camera and shooting in manual mode for better effects... in the second picture having the flash on your right side could have eliminated the shadows under his arm as he is shooting.
sweet rifles
Patrick
Nov 09, 2008 14:56 as a reply to  @ myckul's post |  #7
I use the flash during the day quite often. It fills in the shadows quite well.
Bodies, Lenses, Lights, Stands, Transmitters, Receivers, Tripods, Meters, etc...
1downfall
Nov 09, 2008 17:41 |  #8
myckul wrote in post #6653061 (external link)
sweet rifles
Not trying hi-jack...but i have similar thoughts. What setting would use on day such as he shot for the fill flash? -1/2 or more?
Bill (external link)
myckul
Nov 09, 2008 18:15 |  #9
Downfall,
I would try -1 on a bright day to eliminate the hard shadows but still have some light shadows to keep the shot looking natural.
1downfall
Nov 09, 2008 19:00 |  #10
myckul wrote in post #6654887 (external link)
Downfall,
ty much. I will.
asysin2leads
I'm kissing arse
Nov 09, 2008 19:21 as a reply to  @ 1downfall's post |  #11
This really isn't fill flash. The flash was your main light. Trust me, I did the same thing. The harsh shadow under his right arm is a sign of that. You really don't need high speed sync for this. There really isn't that much motion to this. My advice would be to meter the shot for the available light and set the flash at -1 for fill. Trust me, someone will correct me if I'm wrong.
Kevin
https://www.google.com ….com&ctz=Americ​a/New_York (external link)
Bob_A
Gallery: 48 photos
Joined Jan 2005
Nov 09, 2008 19:54 |  #12
CatchingUp wrote in post #6652845 (external link)
Tilting the flashhead when there is nothing to bounce off of should do nothing except require more flash power. :)
Using a diffuser would help, and maybe dialing down the FEC a bit to balance ambient with flash a little bit better.
Bob
M_ark
Nov 09, 2008 20:17 |  #13
HSS is fine if the OP was trying to blur the background by opening the apeture.(it was AV mode)
-1 or even -1.5 if you're just trying to subtly lift the shadows. (i assume TTL EV in use)
remarkphotography.com (external link)
Canon EOS 40D, 5Dc, EF 24-70 2.8L, Tamron 55-200.
ocabj
Nov 10, 2008 15:39 |  #14
Thanks for the feedback. Like I said, I'm still playing around with the flash, particularly when taking photos at the shooting matches I participate in.
I think the flash is needed in the shooting range environments I am in. Most High Power Rifle ranges shoot towards the north, either favoring North-East or North West, and the sun tends to cause shadowing forward of the firing direction (towards the targets).
woodsie
Nov 10, 2008 18:03 as a reply to  @ ocabj's post |  #15
Try playing around with different settings.
I agree with others. Dropping the flash exposure down would be good in these shots, still creating stong shadows without blacking them out like with no flash. The stong shadows will give a harder more "masculine" look to the shot.
Another approach for some shots is to underexpose the background by 1-2 stops and leave the flash at normal exposure. You have to have the camera in manual mode for this, as in Av or Tv it will wind the flash down to match the ambient exposure correction. This makes the sky a much deeper blue and isolates the subject from the darker background nicely.
Both approaches give different effects appropriate to different situations.
1DMkIIn, 20D and S80 - Full gear list
http://woodsie.smugmug​.com/ (external link)
2,840 views & 0 likes for this thread, 12 members have posted to it.
915 guests, 163 members online
