Thread started 27 Feb 2005 (Sunday) 10:09
Battery Life in the 580EX
happysnapper18
Feb 27, 2005 10:09 |  #1
I recently bought the 580EX flashgun and I have found that if it is left with batteries inserted and the compartment lid closed with the unit switched off, they discharge within 4 days or so. I have never experienced this before with any other make of flashgun. Has anyone experienced this?
kwang0429
Joined Jan 2005
Feb 27, 2005 10:11 |  #2
I did! I had brand new batteries in there, took about 4 pics with flash to test out, a week later, they are automatically discharged!!
Canon 5DII, 15mm F2.8, 50mm f/1.2, 85mm f/1.8, 16-35mm f/2.8L, 24-70mm F2.8L, 100mm F2.8 Macro, 70-200mm F2.8L, 580EX. Stofen Omnibounce. LightSphere II.
DSMITH131
Joined Jan 2005
Feb 27, 2005 10:28 |  #3
had mine a little over a month and haven't changed the batteries yet
Daniel W. Smith Photography (external link)
Mayhem (external link)
Gear
robertwgross
Joined Nov 2002
Feb 27, 2005 10:38 as a reply to  @ DSMITH131's post |  #4
You might want to consider the exact type of batteries you use. There is a huge difference in the self-discharge rates among types such as primary lithium, alkaline, NiMH, and NiCd. Further, some batteries were made with poor quality control, and they quickly become "leaky". There has been a recent push in perfecting NiMH AA-size batteries, with big increases in battery capacity. However, even if you get premium batteries like that, you still have to charge them in a good charger to get good results. If you overcharge a good battery a couple of times, then it becomes "leaky".
---Bob Gross---
kwang0429
Joined Jan 2005
Feb 27, 2005 10:40 as a reply to  @ robertwgross's post |  #5
I used brand new Energizer, but in the other hand, I thought I might had forgot to turn the switch off maybe? until I read this thread, I know I am not the only one who had the problem.
robertwgross
Joined Nov 2002
Feb 27, 2005 10:46 as a reply to  @ kwang0429's post |  #6
kwang0429 wrote:
I used brand new Energizer ...
OK. Energizer brand. What type of battery?
---Bob Gross---
pcasciola
POTN SHOPKEEPER
Joined Sep 2004
Feb 27, 2005 10:51 |  #7
I use Duracell Alkalines in my 580EX, always leave the batteries in and rarely remember to shut the power switch off. I've had it about 3 months and am on my 2nd set of batteries, maybe 200 flashes total.
Philip Casciola
Pro Camera Gear (external link) - POTN Shop (external link)
Canon 7D, EF 50/1.8, EF 85/1.8, EF 300/4L IS, EF-S 18-55, Tamron 28-75/2.8, EF 70-200/2.8L IS
Sigma 1.4x & 2x, Tamron 1.4x, Gitzo 2220 Explorer, 322RC2 grip
happysnapper18
Feb 27, 2005 10:56 as a reply to  @ robertwgross's post |  #8
I use UniRoss 2000mAh Ni-mh batteries, two sets one in and one standby. I used the same batteries in a Sigma EF-500DG Super without any problems of self drain. They have been in there for 3 or 4 weeks without a problem. Use them in the Speedlight and they are fully drained within a week, even when not using the gun.
Page 10 of the instruction manual has a footnote about the Speedlight's settings being retained in memory even with it switched off. Could it be that this feature is the culprit?
robertwgross
Joined Nov 2002
Feb 27, 2005 11:29 as a reply to  @ happysnapper18's post |  #9
There is a particular type of power fault that can occur in just about any electronic product that has a fiberglas circuit board with the main power switch mounted on it. A very fine web of copper salt crystals will "grow around" the switch, and the net result is that there is a low power drain even with the switch Off. This isn't good, and it isn't common, and it is easily repairable (Dremel tool or X-Acto knife), but it causes lots of users to pull out their hair.
The root cause of the crystals is generally insufficient cleaning of the circuit board during manufacture, sometimes caused by use of impure water. Then the crystals continue to grow whenever the power is available in batteries. If you can't get to the repair, then the only work-around is to remove the batteries when not used. That's a pain.
---Bob Gross---
3,346 views & 0 likes for this thread, 5 members have posted to it.
1764 guests, 154 members online
