twiggles wrote in post #6661756
Wouldnt it be easier/more economical/safer to burn those files to DVD instead of relying on removable harddrives?!? Plus DVD is a very easy way to catalog files since you can simply write date ranges or event names on the disk before putting it away...
1 terabyte worth of pictures takes about 218 DVD-R discs to store. Each job ranges anywhere from 2 to 35GB. I tried DVD and it's absolutely painful to find images on discs, especially when they're scattered across 6 discs for one job. Hard drives gives you good performance and searchability.
JeffreyG wrote in post #6662103
Probably because the more compressed JPEGs are good enough for the clients. The compression that is done on JPEGs doesn't do much damage until you drop down past the top slot or two.
We hobbiests can afford to shoot RAW + JPEG fine and save both forever if we wish. I can imagine people shooting loads of stuff professionally who need to keep the files are content with a touch of compression.
dshankar wrote in post #6662258
I see it the other way around. Hobbyists should be content with compression since they don't print 24x36 pictures. Professionals should save RAW + JPEG fine when they need to quickly display content to a client or quickly edit, versus saving all the data for a future, proper post processing.
yup, most clients are fine with an 8MP compressed jpeg. If I have full control of the lighting and it doesn't change much, then I'll zero in the exposure and white balance and shoot jpeg and have zero editing afterwards. Otherwise, for dynamic events like weddings, I shoot RAW. For anything personal, I shoot jpeg. I've also printed a good number of 24x36 fine with a 8MP out of camera jpeg. looks great!
