Thread started 27 Feb 2005 (Sunday) 15:11
10D and Flash
Vlaja
Joined Jul 2003
Feb 27, 2005 15:11 |  #1
OK, I'm pretty sure that I'm not the first one to post this question: Can you use old Vivitar 283 flash on Canon 10D?
Somebody had told me that it would damage the camera (5V trigger, whatever that means) although nothing like that is said in the owner's manual. I wonder if anybody had really tried to do it.
Thanks a million.
v.
tim
Light Bringer
Feb 27, 2005 17:06 |  #2
A quick search found this thread which might be useful to you :)
cmM
Joined Apr 2004
Feb 27, 2005 22:20 |  #3
well high voltage discharges can short your shutter release unit, it's happened to many. I don't know how high that old flash goes / how safe it is.
robertwgross
Joined Nov 2002
Feb 27, 2005 22:37 as a reply to  @ cmM's post |  #4
Every flash unit like that has a trigger circuit that actually fires the main gas discharge tube. In the old flash units of 25 years ago, the trigger circuit had 200-300 volts DC on it, so as the camera's shutter circuit shorts against that, the shutter circuit had to be able to withstand that big voltage. In the newer flash units of the last ten years or so, and like the Canon Speedlites, the trigger circuit has only about 5 volts DC on it, and that is much easier on the camera's shutter circuit. Many modern Canon bodies tolerate only 5-6 volts.
So, you can use old flashes with old cameras, and you can use new Canon flashes with new Canon cameras. When you go mixing old with new, you might possibly burn something up, so there are "safe-sync" devices available to protect cameras, if necessary.
---Bob Gross---
Vlaja
Joined Jul 2003
Feb 28, 2005 11:24 |  #5
Thank you all! I am surprised that Canon did not explicitly note that in the owner's manual.
robertwgross
Joined Nov 2002
Feb 28, 2005 11:40 as a reply to  @ Vlaja's post |  #6
Canon does mention use of a Speedlite (external flash). That is a Canon brand, and as long as you follow that advice, there is no problem.
You translated that to mean any external flash unit, and that can bring problems.
So, it is well-documented and understood.
---Bob Gross---
3,162 views & 0 likes for this thread, 4 members have posted to it.
10D and Flash
1764 guests, 154 members online
