A bit of background. I'm learning, and thought I would experiment with a compact, before buying myself a dSLR... I don't own any proper lighting equipment (except for the in-built flash on my S5)... So thought I'd experiment with some other cheap stuff
Bought some filament bulbs and wires, connected them up and just asked a friend to pose... and heres the result...
Well, you can see three catchlights, the middle is my flash firing and on the right hand side its a 200W bulb (orange light) and on the left hand side its a small emergency lamp (white light) with some glossy white paper right below it (as a reflector
for some light below the chin) I'm guessing two different coloured light isn't a very good idea, but since I was running short, I had to improvise.
Almost forgot, I also set up a 100W orange light bulb at the back of the subject (backlight
ops
Horrible background - curtains drawn during the day (hence the light through it)
I'm sure this set up has a world full of technical flaws, but just wanted to know what everybody makes of it... I tried a B&W conversion (after some skin work + other touchups on CS3). Is it a big failure?
Thanks for viewing, Comments and criticism always welcome.
![]() | HTTP response: NOT FOUND | MIME changed to 'image/png' |
Oh and sorry for the extremely long post...
Was just having some fun...
