Thread started 13 Nov 2008 (Thursday) 09:22
Strobe sync @ 1/400: Pushing the limits.
PhotosGuy
Joined Feb 2004
Nov 13, 2008 09:22 |  #1
Need High-Speed Sync, but don't have the equipment for it? Up to a point, like maybe 1/500 sec., you can fake it!
NOTE: You need an off-camera flash to get the higher shutter speeds, use a sync cord, or tape the pins on some auto flashes.
Shooting V-ball is not all that easy to WB (White Balance). Many of the high school gyms are black holes for lighting; + The lights above are not full spectrum & the light from below which is bounced from the wood floor is biased toward yellow.
And most refs will only allow bounced flash, although some will allow direct flash from the stands in a non-championship match.
So I thought I'd try some tests to see if I could live with the 1/250 sec. sync speed that Canon recommends.
This image was shot against a blank wall to show where the shutter will cut off the flash at higher speeds:
Notice that you can probably get away with 1/400 seconds?
I'm usually shooting with the 85mm f/1.8 lens, which is a bit wide for some angles, so I can afford to crop in, & if I bias the shot toward the top of the frame, I think I can even get away with 1/500 sec as you can see in this image. It's direct flash during warm-up, but bounce flash gives the same result:
So think about squeezing out a little higher shutter speed when you feel that it will help. I suggest that you run a test with your camera like the first image to see just where your shutter cuts off, too.
(Ignore the overexposure. It's just for illustration.)
Wilt
Nov 13, 2008 09:38 |  #2
Just wondering...what would be the reason to up the shutter speed, to simply get rid of the ambient off-balanced light?
PhotosGuy
Joined Feb 2004
Nov 13, 2008 09:49 |  #3
No, to eliminate ghosting from movement at 1/250 sec, which just isn't fast enough to freeze a spikers hand and a volleyball which can move at 100mph.
This shot is at 1/250 sec:
And this one, is at 1/500 without flash fill.
Dermit
Joined Nov 2005
Nov 13, 2008 09:55 |  #4
Wilt wrote in post #6678604 (external link)
There are many instances to try and get higher shutter speeds with flash. The most common for me is on location, outdoors, during daylight. If I want my flash to be a large contributor to the exposure on a subject in full shade but the background is in full sun then a faster shutter will allow me to have a larger aperture which gives me a desired shallow DOF as well as helping out my flash to work less. It's very difficult to get the shutter down to 1/200 in the Arizona sun.. even in shade during the day. And when I often try to underexpose the bright background it only makes matters worse. So this technique PhotosGuy describes could be a viable option, but you really need to know exaclty where your cutoff point is.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
PhotosGuy
Joined Feb 2004
Nov 13, 2008 09:58 |  #5
Good point! I didn't think of that.
Dermit
Joined Nov 2005
Nov 13, 2008 10:05 |  #6
PhotosGuy wrote in post #6678711 (external link)
Oh yes. Believe me, I am mainly an on-location portrait photographer and mostly ourdoors. The higher shutter speed I can get with flash the better. I am constantly trying to walk the fine line of getting descent shots doing this. But once you get it, the shots are killer.
My 5D does not do as well... my 1/400 looks more like your 1/500.... or sometimes even closer to your 1/640.
The world is my backdrop... it provides a lot of variety!
Dan-o
Nov 13, 2008 10:15 |  #7
It is in So. California too. I use a ND filter to get the shutter down to sync speed.
Danny.
DMunsonPhoto (external link)
Cycling Illustrated (external link)
FaceBook Page (external link)
Wilt
Nov 13, 2008 10:33 |  #8
Dermit wrote in post #6678696 (external link)
Thanks, I'm aware of the contribution balance (flash vs. ambient) reason. In fact, the flash vs. ambient color balance issue is another permutation of that same issue. But I was wondering if that was the reason for the OP, so I wanted to know the OP's reason
Wilt
Nov 13, 2008 10:36 |  #9
It's very difficult to get the shutter down to 1/200 in the Arizona sun.. even in shade during the day..
And that is why I love medium format cameras with leaf shutters, like my Bronica outfit...HSS's intensity drop off is a killer, but I can sync to 1/500 with full output of my flash when using the Bronica! Now if only digital backs that fit Bronica were more affordable!
PhotosGuy
Joined Feb 2004
Nov 13, 2008 11:00 |  #10
All right, now confess! You just wanted me to clarify my post! ;)
When I semi-retired, I lost the use of the coolie that shlepped my equipment bags, so I travel even lighter now! :D
Curtis ­ N
Master Flasher
Nov 14, 2008 23:00 |  #11
PhotosGuy wrote in post #6678539 (external link)
NOTE: You need an off-camera flash to get the higher shutter speeds.
Just to clarify: The key is to connect the flash such that the camera doesn't know it's there. An old-fashioned flash like a Vivitar 285HV or Sunpak 383 will work this way, even on the hotshoe.
The Strobist blog ran an article on cheating your shutter speed this way a while back.
jbergdoll
Nov 15, 2008 00:51 |  #12
You don't need a high shutter speed to freeze motion when using flash... Just make sure that your flash is putting out more light than the ambient, at a higher duration. I can shoot at 1/4 and still get the same amount of motion frozen as if I shot at 1/1000 with a Sunpak 544 on half power.
-Joseph
bergdollphoto.com (external link)
gear list
Wilt
Nov 15, 2008 12:48 |  #13
PhotosGuy wrote in post #6679073 (external link)
With the enormous size and weight of 1D series bodies, and of fast L lenses, methinks a Canon 1Ds outfit rivals my medium format for size and mass!
PhotosGuy
Joined Feb 2004
Nov 29, 2008 08:47 |  #14
https://photography-on-the.net/forum/showthre​ad.php?t=606090
eduardofrances
Nov 29, 2008 10:01 |  #15
PhotosGuy wrote in post #6678665 (external link)
thumbnail
Hosted photo: posted by PhotosGuy in
./showthread.php?p=667​8665&i=i11535528
forum: Flash and Studio Lighting
thumbnail
./showthread.php?p=667​8665&i=i97769326
with flash photography the duration of the flash will be your "shutter", regardless of the max sync speed you have set if the flash duration isn't short enough it won't freeze movement.
http://flickr.com/phot​os/eduardofrances/ (external link) :D
16,456 views & 0 likes for this thread
Latest registered member is Cut Out Way
840 guests, 313 members online
