Q: How do you brighten a sunset without blowing out the highlights?
A: You brighten it by making other parts of the sky darker.
That might seem contrary to some suggestions about the image appearing to be dark and that it should be lightened, but illusions can be used to trick the mind.
Additionally, One of my thoughts about the image is that some of the great sky color ought to be reflecting off the water.
With those two thoughts in mind (and some others along the way), I came up with the following edit for what I think is already a great sunset shot. I don't have any particular problem with the piling in the image since it is something that would be expected in this sort of setting. I have the same feelings about the utility poles, antennas, etc. They all have a reason for being in a setting such as this and, to me, use of the cloning tools in Photoshop requires better justification than, "I think that I will do it just because I can".
Most of the miscellaneous adjustments that I made were related to tweaking the color temperature of various parts of the scene to make it appear a bit more homogeneous such as adding a bit of the sunset color cast to the side of the boat in the foreground.
| HTTP response: NOT FOUND | MIME changed to 'image/gif' |
