Thread started 15 Nov 2008 (Saturday) 16:18
Is it my grip
LAMMYPAUL
Nov 15, 2008 16:18 |  #1
hello all,
just wondered if anybody out there has had the same problem as me, only just got my eos 20d body back from lehmanns, after having to have a new shutter fitted (£163), the person who sold me it, said the camera had only done 7000 shots,ha ha ha, but who has not been on since i informed him of the problem.by the way, not off this forum... but thats another story.
well got it back,and tried it out this week with the grip it came with, which is a YXTM C40D.
My problem is that when using the shutter release button on the grip, while shooting in portrait format, the camera fires away no problem, but when i use the shutter release button on the body, it does not always fire straight away, sometimes it take a couple of seconds to fire and then it does not fire at all.
Any ideas, i have done the usual things new fully charged batteries, cleaned contacts on grip, etc.
before i decide to get rid of the grip, and use the camera on its own, i hope someone out there will give me the remedy to my problem.
cheers all, happy snapping
make the most of what you have got.
chris ­ maddock
Joined Mar 2002
Nov 15, 2008 16:38 |  #2
If the grip shutter button works but the body one doesn't always, it sounds more like the body than the grip to me. To confirm that, try shooting without the grip at all and see if the shutter button plays up then.
HTH
Chris
Chris Maddock
Southampton, UK
http://www.dslr.co.uk (external link)
HankScorpio
Nov 15, 2008 16:38 |  #3
So does the button on the body work normally when the grip is removed? Does it work when the grip functions are turned off (assuming it has a switch). It could be the shutter button itself that's contacts are worn and in need of replacement. Failing shutter buttons are a common thing in a well used camera.
My collection of boxes with holes (external link)
EXIF semper intacta.
Gort! Klaatu barada nikto.
LAMMYPAUL
Nov 15, 2008 16:51 as a reply to  @ HankScorpio's post |  #4
hello both, yes the camera works perfect without the grip attached.the camera has had a full service as well as the shutter being done, so i would expect lehmanns to have checked everything while they had it.cheers paul
chris ­ maddock
Joined Mar 2002
Nov 15, 2008 17:16 |  #5
That's wierd, I wouldn't have expected the grip to have any effect on the body shutter button since all it "should" do is replicate the connections that the body button makes - yet it does appear that yours does.
What happens if the grip is fitted but turned off? Does the body button still misbehave?
Chris Maddock
Southampton, UK
bmxfro
Nov 15, 2008 20:46 |  #6
I know that with the grip I have for the 400D, if the shutter speed wheel is in between clicks, it will not let you fire with either shutter. try moving the shutter speed with the wheel on the grip and/or the body, and try again!
BTW, I have a Opteka Grip
Canon 400D Gripped, Canon 50D Gripped, 18-55, 80-200 Zoom, Nifty Fifty, EF 28-135 IS USM x2
noodle_snacks
Nov 15, 2008 20:48 |  #7
Just a random suggestion, but you aren't in "one shot" mode and just not getting focus are you?
jacobsen1
Nov 15, 2008 22:14 as a reply to  @ noodle_snacks's post |  #8
switch to MF on the lens and see if that fixes it...
My Gear List
my sites:
benjacobsenphoto.com (external link) | newschoolofphotography​.com (external link)
GND buyers FAQ
FOR SALE: 5Dii RRS L-bracket, 430II, 12mm macro tube PM ME!
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Nov 16, 2008 10:20 |  #9
The plunger on the shutter release is broken or sticking.
It's relatively common and had it happen to my 30D a while ago as well.
You'll have to have it serviced. Sorry to hear about that.
Gallery: http://tomyi.smugmug.c​om/ (external link)
LAMMYPAUL
Nov 16, 2008 10:41 |  #10
hi tee why, well i have just had the camera serviced and a new shutter fitted by a Canon approved company, so i think everything was checked.
cheers paul
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Nov 16, 2008 11:39 |  #11
They may not have checked the shutter release button or the shutter release button plunger may not been sticking that point.
jtfoto
Joined Nov 2003
Nov 17, 2008 06:17 as a reply to  @ Tee Why's post |  #12
I had exactly the same issue a few years ago with a 10D.
Sure enough it was a stuffed shutter button on the body.
All good after replacement.
EOS5D Plus Grip,2 X EOS 5D11's plus grips, EOS 1VHS, 1DS Mark 2.
Canon 50 f1.8, Canon 17-40 f4 L, 70-200 f2.8 L IS,300 f4 L IS, 24-105L IS, 16-35 f2.8L, Extender EF 1.4, 3 x EX 58011's plus heaps of odds and ends
www.pro-imagephotography.com.a​u (external link)
2,035 views & 0 likes for this thread, 8 members have posted to it.
Is it my grip
1396 guests, 188 members online
