My Fellow POTN Friends,
I have spent the last couple of months educating myself on tripods and ballheads. POTN has been an enormous resource while searching through endless options. I’ve finished my homework, and here’s what I’m leaning towards getting. I would appreciate any feedback you may have.
Background:
I primarily use a tripod for landscapes, weather photography, and macro work, but I’m certainly not limited to these uses. I’ve come to the realization that a good tripod is necessary if you want to discover what your glass is really capable of. As you can see in my signature, I don’t own any heavy artillery, but the 300 2.8 and a 400mm is in my near future. While I’d love to own a 500mm or longer lens, this is not a consideration for the next several years. I'm 5' 10" and travel frequently. Prior hobbies have taken me deep into the mountains, and I would love to tie my participation of these activities into photography.
My Approach:
I am considering two different set-ups. The first one would be a rock-solid tripod that could handle longer focal lengths and absorb vibrations very well (like the winds you sometimes encounter in weather photography). I want it to be robust, but with a manageable weight and size. The second set-up (which will come a little later down the road) would be an uber-light, compact set-up that would be a dream to carry while traveling and backpacking. I realize that both of these tripods can be expensive propositions, but I want to do it absolutely right the first time around.
What I’m considering:
Set-up #1 “Solid as a Rock”
Gitzo 3541
Markins M-20 with a RRS B2 LRII
RRS L-plate for my 40D
RRS L84 plate for my 70-200 2.8
Set-up #2 “The Traveler’s Dream”
Gitzo 1541T
Markins Q3T with a RRS B2 LRII
(Ben’s review really helped me)
Questions that I have:
1) At first, I was very much considering an Arca-Swiss Z-1 paired with the Gitzo 3541. But since Markins is such a favorite here on POTN, I had read many adoring comments about their ballheads during countless hours of research and I now seem to be leaning towards the M-20. Can anyone convince me that I should take a step-back and reconsider the Arca-Swiss Z-1, or is the Markins M-20 just that good?
2) Like I said before, I want to get this right the first time around. Admittedly, this isn’t going to be cheap. But if I go this route, I feel like I will have two top-shelf set-ups that will serve my needs for a very long time. Given my goals, have I overlooked anything?
I really appreciate your time and expertise!
Bryan
so I want to get it right.
The 3541 or 3531 will work for you just fine...its just a matter if the extra collapsed length of the 3531 will be a PITA for you when traveling or hiking.
