Thread started 16 Nov 2008 (Sunday) 09:57
Is 2nd curtain sync with the Cactus v2s possible?
amadain
Nov 16, 2008 09:57 |  #1
I can't seem to get 2nd curtain sync to work with my cactus trigger. I'm using a 430ex. I've tried setting it on camera and on the flash istself and I can't get it to work. The flash fires at the opening of the shutter and doesn't fire for the 2nd curtain.
Anyone else have this problem?
PacAce
Joined Feb 2003
Nov 16, 2008 10:13 |  #2
2nd curtain sync requires a dedicated flash (Canon EX and compatible flashes) connected directly to the hotshoe or via an off-shoe cord in order to work. So, you won't be able to use 2nd curtain sync with the 430EX off camera and triggered by an RF remote unit.
...Leo
amadain
Nov 16, 2008 10:27 as a reply to  @ PacAce's post |  #3
Thanks for clearing that up. So if I get an off shoe cord like this one
E-TTL FLASH SYNC CORD (external link)
wll I be able to do 2nd curtain?
PacAce
Joined Feb 2003
Nov 16, 2008 10:30 |  #4
amadain wrote in post #6697650 (external link)
Yes, assuming it truly is ETTL compatible.
...Leo
amadain
Nov 16, 2008 12:03 |  #5
PacAce wrote in post #6697662 (external link)
What does that mean?
msowsun
"approx 8mm"
Gallery: 18 photos
Nov 16, 2008 12:15 |  #6
I guess PacAce has some doubts about the Chinese copy of the Canon OC-E3 ETTL cord.
I have the same cord, and yes it is fully ETTL compatible.
PacAce
Joined Feb 2003
Nov 16, 2008 12:30 |  #7
msowsun wrote in post #6698017 (external link)
No, I wasn't doubting the cord because it's a Chinese copy. Even Canon sells TTL cords which are not compatible with ETTL flashes. I was just implying that as long as the cord was not a copy of that non-ETTL compatible cord, then it should work.
...Leo
amadain
Nov 16, 2008 12:57 |  #8
Thanks msowsun. Just one question, are there any downsides to having a cord on the flash? I was planning to use the wireless setup for nightclub photography but I'd really like the option of having 2nd curtain.
ifixsharp
Nov 16, 2008 13:13 as a reply to  @ amadain's post |  #9
As long as we are on the 2nd sync topic. I have a 1DMK2N and a 580 flash. Set the 1D to 2nd sync and it always flashes in curtain open...never close. What am I doing wrong? (Sorry about the hijack of the thread) Had the same question for a while.
G
Greg
Photos...http://www.PhotosByRas​berry.com (external link)
5DMK3 | 5DC | 7DMK2 | 1D Mark III | 40D | Canon 24-105mm f/4L | Canon 500mm f/4L | Canon 100-400L | Canon 70-200 IS f/2.8L
msowsun
"approx 8mm"
Gallery: 18 photos
Nov 16, 2008 13:50 |  #10
amadain wrote in post #6698203 (external link)
There is no downside to using a cord other than having to watch you don't snag the cord on something or trip over it. You can also have the cord lengthened, or do it yourself. https://photography-on-the.net/forum/showthre​ad.php?t=123662
Another option is to have a master slave setup with 2 Canon flashes (or an ST-E2 and a flash) and use "Radio Popper" brand wireless triggers. They are the only ones that support the Canon system. http://www.radiopopper​.com/ (external link)
PacAce
Joined Feb 2003
Nov 16, 2008 14:46 |  #11
ifixsharp wrote in post #6698271 (external link)
G
The 2nd curtain sync option on the camera is really next to useless because it only works with those flashes that do not have the 2nd curtain sync available on the flash itself, like the 420EX. Most of the EX flashes starting with the 430EX and up have the 2nd curtain sync available on the flash so it needs to be set there and not on the camera.
...Leo
ifixsharp
Nov 16, 2008 15:08 as a reply to  @ PacAce's post |  #12
Thank you. I guess I will have to look into where that is located. I don't use flash much. I mostly do aviation photography. I know that flash has more bells and whistles than I will ever use...:D
G
Greg
PacAce
Joined Feb 2003
Nov 16, 2008 15:12 |  #13
ifixsharp wrote in post #6698794 (external link)
G
On the 580EX, it's the second button from the right. it's the button that has an icon of a lightning next to the letter "H" and what looks like three arrow heads pointed to the right. Press that button and it'll cycle between high speed sync and 2nd curtain sync as indicated by the same icons displayed on the LCD screen. Just make sure that the flash is in normal operating mode instead of Master or Slave mode since 2nd curtain sync doesn't work in wireless remote mode.
...Leo
ifixsharp
Nov 16, 2008 15:19 as a reply to  @ PacAce's post |  #14
Thanks......
G
Greg
agedbriar
Nov 16, 2008 18:46 |  #15
Thanks for the link amadain, I just ordered one. The extra foot of lenght (compared to Canon's) seems appealing.
And thanks to Mike for testing it out for me.;)
1,602 views & 0 likes for this thread, 5 members have posted to it.
1597 guests, 140 members online
