Thread started 17 Nov 2008 (Monday) 06:46
Transfering Actions from CS3 to CS4?
Tsmith
Formerly known as Bluedog_XT
Nov 17, 2008 06:46 |  #1
I have a few actions of my own in CS3 that I'd like to try out in the trial version of CS4 but for the life of me can't seem to locate them in the Adobe\CS3 folder anywhere. I see the Adobe stuff but not mine. _ :confused:
Any suggestions? ... thanks
gmitchel850
Nov 17, 2008 07:15 |  #2
Photoshop loads actions into a cache. Your original coy of the actions remains where you loaded them from.
If you no longer have your original .ATN files, you can have Photoshop save the individual action sets as .ATN files.
(1) Select an action set.
(2) Open the flyout menu for the Actions palette.
(3) Select the Save actions . . . menu item.
(4) Save the actions wherever you like.
Then go to CS4 and load them. You can drag-n-drop the .ATN files or use the Actions palette flyout menu and the Load actions . . . menu item.
Cheers,
Mitch
http://www.thelightsri​ght.com (external link)
http://www.thelightsri​ghtstudio.com (external link)
Tsmith
Nov 17, 2008 07:18 |  #3
Thanks Mitch, I'll give this a go this evening. Much appreciated!
Bobster
Nov 17, 2008 11:43 |  #4
some actions may fail to work as advertised as a few things have changed in CS4..
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
Gear | Gram (external link) | Ultimate Lens MA FoCal 2 (external link)| Ultimate RAW Editor C1 (external link)
Tsmith
Nov 17, 2008 19:33 |  #5
Worked great Mitch. Most of my Plug-ins have migrated over just fine too. Thanks!
tim
Light Bringer
Nov 17, 2008 20:42 |  #6
Make sure you do this every time you change your actions, and back the actions up, otherwise you'll lose them if you reinstall photoshop or have to reinstall your OS.
Tsmith
Nov 17, 2008 21:14 |  #7
tim wrote in post #6707540 (external link)
Yes, I learned that mistake the hard way some time back ... :-|
3,469 views & 0 likes for this thread, 4 members have posted to it.
863 guests, 133 members online
