In the process of microadjusting my lenses I developed my own test target, as I was not really happy with the targets I'd found at Northlight Images and the like. I constructed a simple target, using Microsoft Paint, to draw simple box shapes and straight lines in various colours, interspersed with plain black lines. I'm not sure how many pixels wide the finest box edges are but I'm assuming 1 pixel, or 2 at the most.
The target starts out from the centre, with boxes/lines at the very finest pitch, surrounded by more boxes/lines one size up, and after a few of those, more boxes/lines another size up. Finally these carefully prepared boxes/lines were surrounded by further boxes/lines of arbitrary width, with the occasional fine line (smallest size) thrown in in black or white. Here is the test target shown at 100% size.
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
This is embedded here as a JPEG, as that is how Flickr chose to host the file, but, being drawn in Paint, the original was saved as a BMP with no compression artefacts etc.. It could also be scaled perfectly in Paint to 2X, 4X and 8X size, again with no artefacts. For some of the editing I needed to work at these magnifications in any case.
To adjust my lens I displayed the target on my 17" 1920x1200 laptop. This meant that viewed close up, while even the smallest lines could be distinguished easily (maybe "easily" is wrong - some might say "just") by eye, they were very small indeed. The first lens I wanted to calibrate was my 100-400, as I really need to squeeze every last drop of performance from that lens for photographing small birds at a distance, and capturing fine feather detail. I set the camera up on a tripod at approx 20' from the target.
Here is a miniature version of what the camera saw at 400mm focal length....
The EXIF is 400mm, 1/80, f/5.6, 800 ISO. Here is a 100% crop, prepared in DPP with sharpening and NR set to 0....
Here is the same crop with sharpening set to 3 in DPP....
I then added my Kenko 1.4X teleconverter and adjusted my focus once more. I forgot to adjust the exposure to compensate for the loss of 1 stop from the teleconverter, so the results are dimmer. Here is a 100% crop, prepared in DPP, with sharpening and NR set to 0.
Finally, here is he same image/crop with sharpening bumped up to 3....
Looking at that last image, note the fine green vertical lines in the upper right hand quadrant. You will see single lines towards the left of that quadrant, double lines further to the right (only two of them) and, further still towards the right, a single triple line of green. I believe these distinct lines show the resolving power to be at the subpixel level. e.g. the triple green line is really just a single solid green line, three pixels wide, but the black gaps you see are the unlit red and blue subpixels between the green subpixels.
Now, I've made a mistake before in thinking that I was resolving individual pixels and sub-pixels from an LCD display before now, when actually I wasn't, but this time I hope I've got it right. If the finest lines that can be drawn by Paint are a single pixel wide then the camera is indeed resolving individual pixels, and even sub-pixels from a high density display at a fair old distance (20') from a lens that is known to be a bit soft when at 400mm and wide open.
If these details were equivalent in size to fine feather detail on a bird then I figure the camera is perfectly capable of resolving/recording those details to my satisfaction. All I need is a sharp lens and accurate focus (and a high enough shutter speed, and light that is not too soft, and a sufficiently low ISO).
