Thread started 18 Nov 2008 (Tuesday) 07:08
white balance lens caps
James ­ P
Nov 18, 2008 07:08 |  #1
Has anyone used a white balance lens cap? I saw one demonstrated the other day and although the idea sounds good, I was wondering if anyone has used one and if they would recommend them. If you have not seen them, they are like an 18% grey card built into a lens cap. You aim at your subject or light source, record the image, then use it to set a custom white balance.
1Dx - 5DIII - 40D - Canon 24-70LII, 100L macro, 135L, 16-35L, 70-200 f4 and 100-400L lenses
- "Very good" is the enemy of "great." Sometimes we confuse the two.
Brian ­ Puccio
Nov 18, 2008 09:47 |  #2
The only big downside I can see is that you'd have to get one for each lens you had. Unless you wanted to just get one, WB with that lens, then swap to the lens you want (and even then, this is far from ideal for various reasons).
All images, unless otherwise noted, are released under the Creative Commons License (external link) so you are welcome to modify any images
KayakPhotos
Gallery: 179 photos
Nov 18, 2008 09:50 as a reply to  @ Brian Puccio's post |  #3
I use the lally cap. It is made of a nylon material and has elastic around the edges so you can fit it on various size lenses. Mine goes up to 77 mm and I have used it on my 50mm f/1.8 which is 52mm I believe. I think that it works pretty good so far. It also makes a handy quick release lens cap, you just pull it off and on real fast and start shooting.
Just a thought from Daniel
Gear
Jon
Joined Jun 2004
Nov 18, 2008 09:54 |  #4
Brian Puccio wrote in post #6710539 (external link)
Well, no, you can get one sized for your largest diameter lens and either use a step-up ring to mount it to your smaller lenses or just hold it over them while taking the picture. Of course, unless you just hold it in position, you still have to attach and detach it to your lens.
But I think the bigger downside is in dealing with mixed lighting conditions. They assume you're aiming the camera at the light source; if you've got mixed light sources, are you really going to be able to get a true sample of all of them with the camera pointed at one position? A grey card target at the subject position will give a much more reasonable value in those conditions, whether you use it to set a custom white balance in-camera or for post-processing adjustments of your RAW files.
Jon
Cocker Spaniels
PixelMagic
Nov 18, 2008 15:06 |  #5
I use both an Expodisc (external link) and a WhiBal (external link) card. If the light is fairly consistent and I can point my camera in the general direction of the light source I use the Expodisc to set a Custom White Balance. Otherwise, especially in mixed lighting conditions, I use a WhiBal card.
Either method is fairly easy to use. With the WhiBal you can save a reference shot to adjust your photos later during post processing or you can use the shot to set a Custom White Balance.
James P wrote in post #6709677 (external link)
MinhThien
Nov 18, 2008 17:45 |  #6
From what i heard it doesn't matter with WB if you are shooting in RAW? Can some one confirm this?
Eric
R6 | rf50L | rf85L DS | ef200L IS | 470ex | 190CXPRO4 | 498RC2 | TT Streetwalker Roller| TT Restro 7 | F-stop Kenti |
James ­ P
Nov 18, 2008 17:55 |  #7
Thanks guys for sharing your experience. I guess I'll stick to my gray card for now.
The notion that it is not nessessary to use a custom white balance because you can adjust WB in PP is, IMHO, just plain wrong. You can adjust so it looks good, (if your monitor is calibrated) but is it what you saw or what you remember?
vibin247
Nov 19, 2008 00:42 as a reply to  @ James P's post |  #8
I have been using one of those Robin Meyers Digital Gray cards, and I must say, I don't think I'll ever need a white balance tool like the ExpoDisc (although I think the X-Rite ColorChecker might be worth it). You just have to make sure the light is hitting it at a 45-degree angle. Or like the WhiBal card, just put in the scene for reference in post-processing.
Manual, manual, manual...
FlyingPhotog
Cream of the "Prop"
Nov 19, 2008 00:56 |  #9
Coffee Filter...
Jay
Jon
Joined Jun 2004
Nov 19, 2008 20:45 |  #10
MinhThien wrote in post #6713510 (external link)
You can adjust later, but you still need a neutral spot to use as a reference. And a grey card works better for that than an ExpoDisc.
Jon
Cocker Spaniels
1,808 views & 0 likes for this thread, 8 members have posted to it.
1590 guests, 139 members online
