Thread started 19 Nov 2008 (Wednesday) 11:18
Extension Tubes - demonstration on various lenses
ken2000ac
Nov 19, 2008 11:18 |  #1
The questions I faced awhile back - sell dedicated Macro lens (100mm) to fund Holy Trinity? Would I be able to maintain my enjoyment of casual Macro photography with extension tubes? What effect would these tubes have on the lenses I have and plan to purchase?
This website has been helpful to me, so I'd like to return the favor. I have a friend considering buying Extension Tubes, so hopefully this will benefit him as well as others.
ALL of these shots were taken with ambient light, wide-open on each of the lenses I currently own, with a 5D. CS2 processing was minimal and consistent on all shots. Slight smart-sharpening @ 50% was added to each re-sized jpeg file. Each shot manually focused at the minimum focusing distance, aiming for the center point.
35L
35mm @ 200 f/1.4, 1600iso - No tubes.
35mm @ 200 f/1.4, 1600iso + one 12mm tube
35mm @ 200 f/1.4, 1600iso + one 20mm tube
35mm @ 200 f/1.4, 1600iso + both 12mm & 20mm tubes to = 32mm. The front element was resting on the subject.
85L
85mm @ 200 f/1.2, 1600iso - No tubes.
85mm @ 200 f/1.2, 1600iso + one 12mm tube.
85mm @ 200 f/1.2, 1600iso + both 12mm & 20mm tubes to = 32mm
85mm @ 200 f/1.2, 1600iso + both 12mm, 20mm, & 32mm tubes to = 68mm
5DSR | 1N RS | TS-E 24L II | 70-300L
ken2000ac
Nov 19, 2008 11:20 |  #2
135L
135mm @ 200 f/2.0, 1600iso - No tubes.
135mm @ 200 f/2.0, 1600iso + one 12mm tube.
135mm @ 200 f/2.0, 1600iso + both 12mm & 20mm tubes to = 32mm
135mm @ 200 f/2.0, 1600iso + both 12mm, 20mm, & 32mm tubes to = 68mm
17-40L
17mm @ 60 f/4.0, 1600iso - No tubes.
17mm @ 30 f/4.0, 3200iso - one 12mm tube. Front element resting on subject.
40mm @ 60 f/4.0, 1600iso - No tubes.
40mm @ 60 f/4.0, 1600iso - one 12mm tube.
ken2000ac
Nov 19, 2008 11:21 as a reply to  @ ken2000ac's post |  #3
and finally, the 24-70L
24mm @ 80 f/2.8, 1600iso - No tubes.
24mm @ 80 f/2.8, 1600iso + one 12mm tube.
70mm @ 80 f/2.8, 1600iso - No tubes.
70mm @ 80 f/2.8, 1600iso + one 12mm tube.
70mm @ 80 f/2.8, 1600iso + both 12mm & 20mm tubes to = 32mm
70mm @ 80 f/2.8, 1600iso + both 12mm, 20mm, & 32mm tubes to = 68mm
I hope this thread has been of assistance to someone!
elader
Joined Nov 2005
Nov 19, 2008 11:39 |  #4
actually this is insanely interesting and needs to be saved. thanks!
Eric
FJR1300 rider
5D mkIII and 1D MkIII
16-35L | 24-105L | 70-200L f/2.8IS | 85 f/1.8 / 50 f.1,4
bobbyz
Nov 19, 2008 11:44 |  #5
Here is one from other side of the spectrum (canon 500mm f4 with all 3 extenion tubes), almost full-frame,
IMAGE: http://www.bobbyzphotography.com/img/v1/p352008660-5.jpg
Fuji XT-1, 18-55mm
luigis
Nov 19, 2008 11:49 |  #6
In case someone is interested:
This is a table of Canon Lenses
http://www.usa.canon.c​om/app/pdf/lens/EFLens​Chart.pdf (external link)
You can find the magnification factor for each lens in the table.
For example if we have a 50mm lens with 0,19x magnification then
0,13 = X /50
X = 6,5mm
If we add a 12mm tube
6,5mm + 12 mm = 18,5 mm
The new maginification is now:
Magnification = 18,5 / 50 = 0,37x
Hope it helps
Luigi
www.luisargerich.com (external link)
Landscape Photography & Astrophotography
My Awesome Gear List
I ­ DREAD ­ ME
Nov 19, 2008 12:46 |  #7
[QUOTE=bobbyz;6718311]​Here is one from other side of the spectrum (canon 500mm f4 with all 3 extenion tubes), almost full-frame,
How far from the bird were you?
Leonard
1DX II** 5D2 ** G1X ** 50mm 1.2L ** 14mm2.8L II ** 24-70mm 2.8L II ** 70-200mm 2.8L II ** 100mm macro 2.8 L IS ** Aquatica 5D2 underwater housing with multiple ports
sonnyc
Joined Jun 2005
Nov 19, 2008 12:48 |  #8
Thanks for the pics. I only have the 20mm tube and haven't used it on the 17-40 yet. I'll give it a shot.
Sonny
Wilt
Nov 19, 2008 13:31 |  #9
4x4rock wrote in post #6718832 (external link)
Don't be surprised to discover an inability to focus close enough, when using 20mm tube and the short FL settings of the lens...from 17 to about 20mm, for example.
bobbyz
Nov 19, 2008 15:13 |  #10
[QUOTE=I DREAD ME;6718814]
bobbyz wrote in post #6718311 (external link)
Pretty close, like 5-6 feet but I am not good at guessing distances.
Fuji XT-1, 18-55mm
str8six
Nov 19, 2008 17:23 |  #11
luigis wrote in post #6718342 (external link)
0,13 = X /50
X = 6,5mm
Hope it helps
Luigi
I must be missing something here. Your table shows 50 mm magnification factor of 0.15 for both 50mm lenses. You speak of 0.19 but use 0.13 in your formula. I'm lost.
Regards, Len B
justincase724
Nov 19, 2008 17:53 |  #12
Very interesting. I've been thinking about getting a set of extension tubes for a while now, just haven't done it (spending that money elsewhere). Thank's for taking the time to put this together.
FLICKr (external link) GEAR
I ­ DREAD ­ ME
Nov 19, 2008 18:13 |  #13
[QUOTE=bobbyz;6719891]
I DREAD ME wrote in post #6718814 (external link)
So by using the extension tubes you reduced the MFD by 66%?
Does that work for most lenses?
Sorry for my stupid question:confused:
Leonard
Wilt
Nov 19, 2008 18:20 |  #14
[QUOTE=I DREAD ME;6721098]
bobbyz wrote in post #6719891 (external link)
At infinity focus, the reproduction ratio of the lens is in proportion to the extension tube length...e.g. 12mm tube on 36mm lens is 1:3 final size (on sensor) while 12mm tube on 120mm lens is 1:10 final size.
But 'How much closer than without extension tube' is dependent upon the internal focusing mechanism built into the lens itself, and this is very design dependent... the 'how much closer' would be very different for 50mm f/1.4 lens vs with the 50mm f/1.8 lens, for example.
ken2000ac
Nov 19, 2008 21:17 |  #15
Glad this is proving somewhat helpful. For the casual macro-photographer, extension tubes may prove to be the best choice. For me...
1.) I saved money to put towards other items that better suited my shooting style.
2.) I saved weight and opened an extra space in my bag.
3.) I added functionality to all of my lenses.
I found the following post helpful this summer while I was making my decision: https://photography-on-the.net …php?p=5708562&p​ostcount=7
3,454 views & 0 likes for this thread, 14 members have posted to it.
1319 guests, 124 members online
