Thread started 19 Nov 2008 (Wednesday) 13:57
Problem with CS4 Plugins
John ­ E
Nov 19, 2008 13:57 |  #1
Do CS3 plugins work with CS4? I copied them from the CS3 plugin directory into the CS4 directory. However, when I open CS4, and look in the filter tab, none are listed? Can anyone help?
John Elser
Canon 5D MK II; 30D; EF 85 f/1.8; EF 70-200L f/2.8 IS II; EF 24-105L f/4; EF 135L f/2; EF 24-70L; Canon 580 EX II(x3).
PixelMagic
Nov 19, 2008 13:59 |  #2
What specific plug-ins are you referring to?
John ­ E
Nov 19, 2008 14:11 |  #3
Nik Color efex Pro, Pictorcolor iportrait, Tiffen Dfx, Topaz adjust, Imagenomics Portraiture, Vertus Fluid Mask, Noise Ninja, are a few.
John Elser
PixelMagic
Nov 19, 2008 14:26 |  #4
Hmmm.... There was a problem with the Nik Software plug-ins where the Nik Selective Tool caused Photoshop CS4 to lose focus resulting in all the menus becoming "greyed out" on startup. This was fixed in a November 6 release...in fact all the Nik plugins were updated on that date to fix CS4 compatibility problems so it would be worthwhile to download the latest versions.
I have all the others listed except the Pictocolor and they work fine under CS4. Are you sure you copied them to the correct folder?
John ­ E
Nov 19, 2008 15:00 |  #5
I copy them to the "Plug-ins" folder, correct?
John Elser
PixelMagic
Nov 19, 2008 15:30 |  #6
Yes, they should be placed in the C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-ins folder (assuming you're a Windows user).
It shouldn't make a difference but whenever a new version of Photoshop is released I reformat my hard drive and reinstall everything from scratch. Its a tedious project but I've managed not to have all the problems so many people report.
iof
Joined Mar 2004
Nov 19, 2008 17:22 |  #7
Are you on a 64bit system? Are you trying to make them work with the 64bit version of CS4?
Ron.
5D,20D, D60, Elan 7, Canon stuff from the 70's, Pentax stuff from the 60's, other stuff.
slicjoc1
Nov 19, 2008 17:38 |  #8
I had the problem with Imagenomics Portraiture and Noiseware. I copied the Imagenomics folder (under Plug-ins) in CS3 into the CS4 Plug-ins folder. The problem was solved after rebooting CS4.
gmitchel850
Nov 19, 2008 18:12 |  #9
slicjoc1 wrote in post #6720887 (external link)
Yes, Slicjoc raises an important point.
Did you leave CS4 after you copied the plug-ins?
Photoshop looks for plug-ins (and for scripts) at start-up. That's it. If you add them while Phjotoshop is running, it will not see them.
Always close Photoshop and start it again after adding a plug-in or script.
Cheers,
Mitch
http://www.thelightsri​ght.com (external link)
http://www.thelightsri​ghtstudio.com (external link)
gnirtS
Nov 19, 2008 18:45 |  #10
This could be 32 bit plugins in the 64 bit photoshop.
Try loading photoshop manually (not via bridge) and load "Photoshop CS4" NOT the (64 bit) one. Then see if they appear or can be loaded. I know noise ninja will only work via 32 bit PS launched this way - it wont appear on 64bit.
flickr: http://www.flickr.com/​photos/whitcomberd/ (external link)
http://www.hvsac.co.uk (external link)
Tsmith
Formerly known as Bluedog_XT
Nov 19, 2008 19:52 |  #11
I would try any CS3 Plug-ins one at a time for compatibility issues. A common CS4 Plug-in error will sometimes bring up an error box with, Owl Orphanage: Photoshop.exe unable to locate compionent _ CoreFoundation.dll
John ­ E
Nov 20, 2008 07:55 |  #12
Yes, my machine is 64-bit Windows Vista, and I have tried copying the plug-ins one at a time in the "C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-ins" folder, and I've also tried re-booting the machine, but they still don't show up under the filters menu. It's got me baffled. By the way, I'm using the CS4 "Extended" try out version. Would this make a difference?
John Elser
iof
Joined Mar 2004
Nov 20, 2008 08:41 |  #13
32bit plug-ins will not work in the 64bit version of photoshop. However, if you installed with default options, you should have installed both a 64bit version and a 32bit version(If you installed from CD as I did). The 64bit version is in C:\Program Files and the 32bit version is in C:\Program Files(x86). 32bit plug-ins should work in the (x86) version of photoshop. Venders will have to write 64bit versions of their plug-ins to work with photoshop(64).
Ron.
iof
Joined Mar 2004
Nov 20, 2008 08:59 |  #14
Found this in Adobe kb404439:
Allocating memory with 64-bit processors
Photoshop CS4 installs both a 32-bit and a 64-bit version when you install on a 64-bit version of Windows Vista and Windows XP. If you use the 32-bit version of Windows, Photoshop only installs the 32-bit version.
If you run Windows Vista, upgrade to Service Pack 1 for better performance.
Note: Although 64-bit Photoshop CS4 was not thoroughly tested under Windows XP64, and therefore is not supported, it should run.
Photoshop installs a 32-bit and a 64-bit shortcut into the Start Menu. If you need to manually run the application, the 32-bit version is the photoshop.exe file, in the Program Files (x86)/Adobe/Adobe Photoshop CS4 folder, and the 64-bit version is the photoshop.exe file in the Program Files/Adobe/Adobe Photoshop CS4 folder.
Third party plug-ins written for 32-bit versions of Windows will not work when you run the 64-bit version of Photoshop. If you need to use plug-ins that haven't been updated, run the 32-bit version of Photoshop. When you are done using the plug-ins, close the 32-bit version, and run the 64-bit version. Contact the plug-in manufacturer for information about any updates.
Ron.
John ­ E
Nov 20, 2008 09:25 |  #15
Thanks a million for all your comments. A special thanks to "iof" who finally solved my problem. I love this forum!
John Elser
8,117 views & 0 likes for this thread, 8 members have posted to it.
498 guests, 126 members online
