When fudging about with the curves in the individual color channels, is that saturation, or what?
Say you take the green channel and pull it straight down from the middle. What exactly is that doing? Saturation, hue? Something else?
cdifoto Don't get pissy with me 34,090 posts Likes: 44 Joined Dec 2005 More info | Nov 21, 2008 03:22 | #1 When fudging about with the curves in the individual color channels, is that saturation, or what? Did you lose Digital Photo Professional (DPP)? Get it here
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Nov 21, 2008 03:43 | #2 Wow, great question! Isn't it funny how you can use something every day, and instinctively know exactly how it works, yet not be able to explain it!
neumanns Goldmember 1,465 posts Likes: 1 Joined Feb 2007 Location: North Centeral Minnesota More info | Nov 21, 2008 09:06 | #3 Post deleted! 7D, Sigma 8-16, 17-55, 70-200 2.8 IS, 580ExII, ........Searching for Talent & Skill; Will settle for Blind Luck!
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Nov 21, 2008 14:53 | #4 Obviously you change color. "I think the idea of art kills creativity" - Douglas Adams
gmitchel850 Senior Member 279 posts Joined Oct 2008 Location: Tallahassee, FL More info | Nov 21, 2008 16:06 | #5 Saturation measures the amount of gray in a color. It is distinct from basic hue. It is distinct from lightness (how light or dark a color appears). http://www.thelightsright.com
Nov 21, 2008 16:14 | #6 Damo77 wrote in post #6730559 Wow, great question! Isn't it funny how you can use something every day, and instinctively know exactly how it works, yet not be able to explain it! Taken in isolation, a green channel midtone adjustment is both a saturation and lightness adjustment. After all, the range of each channel is from 0 (black) to 255 (completely saturated colour). So to move the middle of the green slider up would be to move it towards spectral green (is that the right word?), therefore lightening and saturating; to move it down would be to move it towards black, ie darkening and desaturating. However, you can't actually look at it that way, because a curves adjustment on any channel adjusts all colours which contain that channel's colour. In your example, to pull green down does all sorts of things: darkens greens, saturates magentas, pinkens neutrals and all other colours to varying degrees. So no, a curves channel adjustment isn't doing a Hue or Saturation adjustment, which can be performed on individual colours, or on all colour equally, and doesn't affect neutrals. Curves affects all colours, but not equally, and definitely affects neutrals. Thanks amigo. This so far is closest in getting at what I wanted to know. Did you lose Digital Photo Professional (DPP)? Get it here
gmitchel850 Senior Member 279 posts Joined Oct 2008 Location: Tallahassee, FL More info | Nov 21, 2008 17:15 | #7 First. LR has Curves. http://www.thelightsright.com
Nov 21, 2008 17:22 | #8 First. LR has Curves. Of course, but It's an RGB tone curve. It doesn't have the full functionality as the Photoshop curve tool. That's why I started the thread - to figure out what the workaround would be. Did you lose Digital Photo Professional (DPP)? Get it here
gmitchel850 Senior Member 279 posts Joined Oct 2008 Location: Tallahassee, FL More info | Nov 21, 2008 17:47 | #9 Not everything in PS has a workaround in LR. http://www.thelightsright.com
neumanns Goldmember 1,465 posts Likes: 1 Joined Feb 2007 Location: North Centeral Minnesota More info | Nov 21, 2008 21:00 | #10 Now if I could have only put into words what Mitch has said I would not have needed to delete my post. 7D, Sigma 8-16, 17-55, 70-200 2.8 IS, 580ExII, ........Searching for Talent & Skill; Will settle for Blind Luck!
Nov 21, 2008 21:02 | #11 gmitchel850 wrote in post #6734894 Not everything in PS has a workaround in LR. ![]() I have tools that do make adjustments to individual channels with Curves. My TLR Color Compensating Filters action set is one example. There is no simple formula for converting a Curves adjustment in Photoshop to a simple combination of pulling of sliders in LR. I understand what you want to do. I'd like to do it, too. What you propose to do, will not work. Consider the saturation slider. That is going to increase/decrease the saturation of every pixel by the same amount (until an individual pixel gets pushed to 100% with an increase or 0% wth a decrease). Curves, however, is designed not to affect every pixel identically. It is designed to affect some pixels more than others. The same maneuver -- pulling one point along the curve for one channel -- will have many different effects. Let's say you pull the Red curve so 128 becomes 135. Saturation for some pixels can increase. Some will remain unchanged. Some can even decrease. Increasing Red in isolation does not necessarily increase saturation. For pixels that were say 128,0,0 -- yes. They are now 135,0,0. Their saturation increases. But, what about pixels that were 128,135,135? The same adjustment to the Red channel made them neutral gray. Their saturation just fell to 0%. They are 135,135,135. Cheers, Mitch That's pretty much what I was asking... Did you lose Digital Photo Professional (DPP)? Get it here
| Latest registered member is semonsters 1613 guests, 141 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
