My question is I suppose very basic. Is a Hoya Skylight filter the same as a Hoya UV filter? If it is the same why the different names? Also finally, what does pitch 0.75 mean which is printed on the filters case? Thanks for your help.
boz Hatchling 6 posts Joined Feb 2005 Location: Dorset England More info | Mar 02, 2005 20:48 | #1 My question is I suppose very basic. Is a Hoya Skylight filter the same as a Hoya UV filter? If it is the same why the different names? Also finally, what does pitch 0.75 mean which is printed on the filters case? Thanks for your help.
Nabil-A Goldmember 1,000 posts Likes: 1 Joined Dec 2004 Location: Melbourne, Australia More info | Mar 02, 2005 21:21 | #2 _______________
infeeneetee Member 119 posts Joined Jan 2005 Location: Malaysia More info | Mar 02, 2005 21:32 | #3 nabil .. since i use UV filter on my g6 im getting problem with lens flare.. any idea?
Nabil-A Goldmember 1,000 posts Likes: 1 Joined Dec 2004 Location: Melbourne, Australia More info | infeeneetee wrote: nabil .. since i use UV filter on my g6 im getting problem with lens flare.. any idea? It is a well known fact that mounting filters increases your risk of flare or unwanted reflections in your camera. Usually occurs when you shoot to close to a light source (like the sun). The more glass/air interface in the lightpath to the CCD, the more likely flare becomes. Multicoated filters and lenses may subdue flare, but can only do so much. _______________
infeeneetee Member 119 posts Joined Jan 2005 Location: Malaysia More info | Mar 02, 2005 21:57 | #5 thanks for the info nabil
| Latest registered member was a spammer, and banned as such! 2462 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
