my friend whos into photography says my camera has some hot pixels inside
i have supplied a picture so someone can explain what they are
tongard Senior Member More info | Nov 25, 2008 14:01 | #1 my friend whos into photography says my camera has some hot pixels inside Canon 6d, 7d2.
bacchanal Cream of the Crop 5,284 posts Likes: 22 Joined Jan 2007 Location: Fort Wayne, IN More info | Nov 25, 2008 14:04 | #2 |
tonylong ...winded More info | Nov 25, 2008 14:08 | #3 Heh! I haven't responded to this because I can't tell whether it's serious or not! Tony
Shasta Goldmember 1,244 posts Likes: 1 Joined Mar 2006 Location: Windsor, ON Canada More info | Nov 25, 2008 14:29 | #4 If they are serious, get some new friends.
alt4852 Goldmember 3,419 posts Likes: 1 Joined Oct 2007 Location: Northern Virginia More info | longer exposures make them more obvious. taking a picture of the reflection in the front element of your lens is not indicative of hot pixels on your sensor. 5D4 | Z21 | 35L2 | 50L | 85L2 | 135L
jcp2000 Senior Member 988 posts Joined May 2008 Location: California More info | Nov 25, 2008 14:37 | #6 uhh the little red dot in the middle might be a hot pixel i had the same problem. Canon 7D, Sigma 24-70 f2.8 EX DG, Vivitar 285HV, AlienBees B800, Vagabond II, Cactus V2s, SLIK Able 300 DX
Shasta Goldmember 1,244 posts Likes: 1 Joined Mar 2006 Location: Windsor, ON Canada More info | Nov 25, 2008 14:41 | #7 jcp2000 wrote in post #6757907 uhh the little red dot in the middle might be a hot pixel i had the same problem. take off your lens put the body cap on the body put enable the manual cleaning on leave mirror up for 30sec or longer and then turn off the camera. should go away if not repeat steps but add more time to the mirror being up like a minute or longer ????????? ^
Perfect_10 Goldmember 1,998 posts Likes: 7 Joined Aug 2004 Location: An Ex Brit living in Alberta, Canada More info | Actually the bottom one is hot .. the top one looks like it's cooled down somewhat ..
Brian1cj Senior Member 254 posts Joined Jan 2008 Location: Grand Blanc, Michigan, USA More info | Nov 25, 2008 19:04 | #9 Shasta, I think I see the big dipper! SOLD:Canon 5D mk III | 430ex |70-200mm f2.8/L IS [COLOR=#000080]| 24-70mm f2.8L | 85mm f1.2L | 100mm f2.8mm macro | 50mm f1.8
Shasta Goldmember 1,244 posts Likes: 1 Joined Mar 2006 Location: Windsor, ON Canada More info | Nov 25, 2008 19:11 | #10 ^^ hehe.
tonylong ...winded More info | Nov 26, 2008 01:45 | #11 If they had a 5D, the hot pixels would be bigger, but at least there'd be more of 'em...and with a shallower depth of field! Tony
empire88 Member 166 posts Joined Nov 2008 Location: Central California More info | Nov 26, 2008 01:51 | #12 Take your lens off and get some soap, water, and a sponge.
| Latest registered member is Niagara Wedding Photographer 1431 guests, 146 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
