Thread started 27 Nov 2008 (Thursday) 05:48
Need advice on G10 E-TTL in Creative modes
johnz
Nov 27, 2008 05:48 |  #1
Hi,
Just got my first G-series, and i have a question about the E-TTL on AV, TV, M modes.
I don't get how is it supposed to work, it seems like the flash is always on manual mode when i am on of the above shooting modes.
When i go to the Built in flash settings the flash output can only be minimun, medium or max. How can i choose E-TTL?
When i use the green box mode the flash exposure is ok, but in other modes the E-TTL doesn't seem to be working. The same thing happened when i used a 430 EX flash with this G10.
Any advice how to get it to work like ETTL is supposed to? The manual flash just doesn't work for me..
EDIT:
Ok, tested this a little more. The camera gives me E-TTL + FEC functions when i am in Av / Tv modes, but only full manual flash ( with only 3 steps adjustment ) when i am in M mode.
How sad is this? Makes the M mode useless in normal indoor photography IMO, because who really uses manual flash with ON CAMERA flashe anymore? It's a pain to adjust and it's never correct without a few test shots.
Certainly one can argue that why should i be using M mode when shooting indoors, but i am just used to using M from DSLR world, and it's really quite easy when camera has a working E-TTL flash for giving a little fill and freezing the motion.
- Tuomas Gustafsson
My smugmug (external link) - ( still on the works )
My gear list/ DOF calculator for Nokia phones
With Canon you can... spend all your money on glass.
Digitalartist
Nov 27, 2008 23:45 |  #2
I suggest you read the manual. I bought the G10 as a backup to my 1DsM2 and for only 2 other reasons. The RAW capability and the Manual mode. Setting the dial on M, and hitting the metering mode button will let you cycle between adjustments for aperture and shutter speed and you can see in realtime Live View, the effect this has on your image. This lets you make extremely accurate minute adjustments to your exposure to get exactly the light that you want.
Yusuf Hashim (external link)
I keep a few pictures HERE (external link)
johnz
Nov 28, 2008 02:02 |  #3
Digitalartist wrote in post #6771876 (external link)
I suggest you read again what i asked.
I wasn't talking about Aperture or Shutter speed or metering modes. I was asking about E-TTL in Manual mode? Any answer on that?
- Tuomas Gustafsson
rpolitsr
Joined Jun 2005
Nov 28, 2008 03:23 |  #4
I have a Pro1. It is similar to other G-series cameras up to the G6 in many things. I’m not sure with the G9 or G10, but with a Canon external flash it works great.
Here is what my User Guide says about external flash operation:
Pro1 User Guide wrote:
  • In M mode or when [Flash Adjust] is set to [Manual], the flash will
    fire with manual adjustments. . .
  • When [Flash Adjust] is set to [Manual], the flash output can be
    adjusted. When [Flash Adjust] is set to [Auto] the flash exposure
    compensation can be adjusted. . .
  • In M mode or when [Flash Adjust] is set to [Manual], the output of
    an externally mounted flash can be adjusted in the flash output
    adjustment screen ( p. 108 ). When a Speedlite 550EX, a Macro
    Ring Lite MR-14EX or a Macro Twin Lite MT-24EX is mounted on
    the camera, you can adjust the flash output from either the flash or
    the camera. (The flash setting overrides the camera setting when
    both are set.). . .
I guess the G10 will have a similar behavior.
I will check the G10 manual as soon as I can, but it will not be too soon, sorry.
rafael
Canon EOS Rebel XT, EF-S 18-55mm f3.5-5.6 II, EF 50mm f1.8 II, EF-S 55-250mm f/4-5.6 IS STM, speedlite 430EX, basic filters set.
My photo galleries (external link)
Marketplace: PAYPAL GIFT NO LONGER ALLOWED IN POTN
johnz
Nov 28, 2008 03:31 |  #5
rpolitsr wrote in post #6772473 (external link)
The G10 seems to work with E-TTL ( internal or external flash ) nicely when in TV, AV modes, but when i switch to M the "Auto" setting dissappers from the flash control menu.
I don't understand why canon would make it work like this, makes no sense to me taking flash metering away from Manual mode.
- Tuomas Gustafsson
GordonSBuck
Joined Jan 2003
Nov 28, 2008 18:58 |  #6
johnz wrote in post #6772297 (external link)
There is no E-TTL in Manual mode for the Canon Powershot G10 -- or any of the Powershot G series. Manual exposure mode means all manual -- including the flash and whether the flash is the little built-in flash or the fanciest Canon external flash. The Powershot G series E-TTL flash is different from Canon DSLR cameras when in manual exposure mode.
Gordon
http://lightdescriptio​n.blogspot.com (external link)
My 10 Best Photos: http://hornerbuck.smug​mug.com …187_MdCXA#56343​6691_UdXpt (external link)
johnz
Nov 29, 2008 05:20 |  #7
GordonSBuck wrote in post #6776000 (external link)
Thanks for your answer! I just found that hard to believe.. i don't get it why would they cripple the camera like that.
Well, i guess i just have to get used to shooting in TV, AV modes for indoor shots now instead of M. Thanks!
- Tuomas Gustafsson
4,830 views & 0 likes for this thread, 4 members have posted to it.
1747 guests, 171 members online
