i'm using a 430ex flash currently with my new cactus v2s units and am getting very unreliable and unsatisfying results. will the vivitar 285HV flash give me more reliablility? thanks!
hecster Member 249 posts Joined Jun 2008 Location: San Jose, CA More info | Nov 28, 2008 03:26 | #1 i'm using a 430ex flash currently with my new cactus v2s units and am getting very unreliable and unsatisfying results. will the vivitar 285HV flash give me more reliablility? thanks! 40D | 50mm 1.8 | 24-105L |17-55 2.8 | 430EX | vivitar 285hv | CyberSync
DannyG Member 74 posts Joined Nov 2006 More info | Nov 28, 2008 08:03 | #2 I think if you do a search on the cactus v2s you will find that unreliable is the most often word associated with them. But they are inexpensive and if you can live with the occasional misfire and not so good performance outdoors, they are the best bank for the buck. I don't think changing the flash will make that big of a difference. You may also want to try looking at the antenna modifications that are posted within these forums. _______________
Nov 28, 2008 08:52 | #3 Indoors the V2s are very reliable with my Vivitar 285's. However with my 580 EXII they tend to randomly fire.
SnlpeR Goldmember 1,013 posts Joined Dec 2007 More info | i have no problems firing 580exII, 580ex, 540ez, sunpak383, some old vivitar...and some older starblitz
Nov 28, 2008 11:05 | #5 yeah, these things definitely fall into the "you get what you pay for" category. but since i'm just starting to get into the flash realm, i think it's a good first step. i've been looking at all these different threads about cactus triggers, and it seems that the worst performance is when they're paired up with the 430ex. my next step will be doing the antenna mod, as it seems to cut the unreliability in half. 40D | 50mm 1.8 | 24-105L |17-55 2.8 | 430EX | vivitar 285hv | CyberSync
rnourse Member 199 posts Joined Mar 2008 Location: Toronto, Canada More info | Nov 28, 2008 21:53 | #6 Someone did a great test on changing the frequency to alleviate these issues... the test is here
Nov 28, 2008 22:10 | #7 I'm using the V2s with Sunpak 383s. Indoors they aren't really that bad. I shot with them for the first time outdoors last night, and for every 7 shots...they would misfire. eeeksNYC (my blog
| Latest registered member is SteveeY 1691 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
