FORUMS Photo Sharing & Visual Enjoyment Astronomy & Celestial
Thread started 01 Dec 2008 (Monday) 11:34
tips on shooting Moon, Jupiter and Venus Conjunction.
photorookie
Dec 01, 2008 11:34 |  #1
I live in Kansas and hope to try to get some shots of the Moon, Jupiter and Venus Conjunction tonight. My longest lens is a 70-300L f4 IS but also have a Canon 200L and a 1.4x converter available. From there I go down to a 24-70L and a canon 10-22 as well. Also have a Canon 135L in the middle of all this.
I dont do much of this type of photography and am curious about suggested settings and lens choice to use. my camera is an XTi and will be tripod mounted.
Thanks!
jmik26
Dec 01, 2008 12:51 |  #2
Hopefully someone with experience will drop a line. I would assume to use your fastest lens to keep shutter speeds up. I am going to try and get a clean moon shot and hope the 2 planets come out alright? I was looking at some of the exif from other photos and they are using 20mm all the way up to 400mm...Jeff
www.jmikosphotography.​com (external link)
Adrena1in
Dec 01, 2008 13:24 |  #3
The moon and the planets are closer than I expected...in fact the moon occulted Venus earlier...I watched as Venus popped out, and regretted massively having a flat camera battery.
I'm not familiar with any of your lenses, but I would say the 200L with the 1.4x or the 70-300. Open the aperture, then fire off some shots from 0.1s to 1 or 2 seconds perhaps. Personally I like to get the dark-side of the moon showing up if I can.
Should get some nice results I hope. Wide-angles with some interesting fireground objects will also make for good photos.
Canon EOS 450D, Sigma 18-200mm, Canon 50mm f/2.5 Macro, 2x TC, Revelation 12" f/5 Dobsonian, Mintron PD2285-EX webcam.
timeasterday
Dec 01, 2008 15:13 |  #4
You'll need around 200mm focal length if you want a tight shot. Of course wider FL's with some foreground objects are nice too. There's a few breaks in the clouds here (finally!) so maybe I'll get a shot. Last night I was taking 15-20 second exposures at ISO200 with a 24mm lens.
7DMKII, 5DMKII, Canon 17-40L, Canon 100mm f/2.8 Macro, Canon 70-200mmL f/2.8 II, Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary, Zeiss ZE 50mm Makro Planar, Rokinon 14mm f/2.8, Kenko Pro 300 DG 1.4x TC, Canon 2X III TC, 580EX II x2, YN560, RF603's
My Smugmug (external link) | Flickr (external link)
photorookie
Dec 01, 2008 15:17 |  #5
timeasterday wrote in post #6792608 (external link)
do you use a remote shutter release with those, I have a tripod but no release
photorookie
Dec 01, 2008 15:22 as a reply to  @ photorookie's post |  #6
Does this work??
2. Moony 11, 8, and 5.6 Rules
There are many different rules that work well when shooting the moon. One favorite for a proper exposure of a full moon is f/11 at one over the ISO setting. For pictures (external link) of a half moon, use the same shutter speed at f/8, and for a quarter moon, use the same shutter speed at f/5.6.
Dusty
Dec 01, 2008 15:26 as a reply to  @ photorookie's post |  #7
The 135mm will give you a nice field of view ( see my shot with it) and the 200mm will get in closer.
Don't use anything longer.
If you haven't got a remote release, put it in delay mode and it will help.
Dusty
20Da, 7D MkII, 5DII,1DX, 16-35L , 24-105L , 85L , 135L , 200L f/2.8 , 300L f/2.8 , MP-E 65
timeasterday
Dec 01, 2008 15:39 |  #8
photorookie wrote in post #6792640 (external link)
Oh yes, forgot to mention that. Timer mode, as mentioned above, works well too.
1,374 views & 0 likes for this thread
Latest registered member is Notvalid
702 guests, 264 members online
