Thread started 01 Dec 2008 (Monday) 11:38
24-70, same ol story
single_track
Dec 01, 2008 11:38 |  #1
Frustrating but somewhat expected, I purchased a 24-70L that turned out to be a bit too soft, especially wide open. I am reasonably confident that my comparison tests were not user error (solid tripod, manual and AF, MLU, etc.). When testing it prior to purchase, I found it to be soft or mis focusing but it was their only model and I wanted to better test under controlled conditions. I expected to buy and return/replace if not satisfied. My tests knowingly pitted it against some tough competition (70-200/f4 IS and my nifty) as well as a lens it should have outperformed (17-85 IS). The 70 was not horrible but not quite right.
I bought it locally so I could easily replace and send out for repairs. The dealer has been very understanding thus far, knowing the issues and potential for this to happen. They ordered two units so I can select the best. They will also return to canon if need be for calibration. I expected this but still wanted this lens for my 5d and 40d.
I used it over thankgiving for family shots. Handling, focal range and speed was great on the 5d. The attached 100%'er shows the focal plane to be aligned with the sweater slightly infront of her eyes (hand held and I think I recomposed). The sweater is relatively sharp but not great, IMO. This is one of the sharpest 2.8 shots taken this day. I am not saying this is horrible, just not as good as it should be. Also, I regognize the 'learning curve' of a fast lens and the DOF is about 4" in this shot. Shutter speed was pretty quick at 1/200 (ISO 800).
I can't wait to get this behind me, get my lens back and enjoy my new toy. I hope I say it was worth it a month from now.
I always want C&C on my shots.
Gear list: 70d, 5d & 40d | 70-200L/f4 IS | 24-70L | 17-40L | Sigmalux | 17-85 IS | Opteka 6.5mm fisheye | 580exII
Flickr: https://www.flickr.com​/photos/120400139@N03/ (external link)
Mr. ­ Clean
Dec 01, 2008 12:38 |  #2
Personally I think it's best to just send the original puchased lens in for calibration and not play the swapping game. The vast majority of 24-70's are good so it's just due time until you get one you're happy with. Plus it's such a great lens...
Mike
some shots @ Zenfolio (external link)
single_track
Dec 01, 2008 13:00 as a reply to  @ Mr. Clean's post |  #3
Thanx, I agree and is what I originally wanted to do, except the unit I bought has a tight focus ring at the wide angle. Moves easy at longer lengths but is tougher to turn when wide. I thought I could get used to it but it drove me crazy for the couple days that I had it. I held other 24-70's before that did not do this.
I was wondering how many who owned this lens have the same focal length resistance issue.
If it was not for the sticky ring, I would have simple sent it in for calibration.
Papa ­ Carlo
Dec 01, 2008 15:26 |  #4
single_track wrote in post #6791894 (external link)
The tight ring will loosen up sooner than you realize.
Yes it looks like your lens is frontfocusing. Just to relieve you I have never bough a lens that was exactly correct out of the box.
The only lens that focused correctly is 28-135 that came in a kit with a camera. 17-85, 17-55, 70-200/2.8L IS and 24-70/2.8L all had some amount of front focus and had to be sent to Canon. Those guys really should take their acts together do some changes in their QC department.
So there is no guarantee that you will get better lens on the second round.
Yes some change four lenses before buying or not buying at all but I am not convinced that anything would satisfy such buyers at all.
queenbee288
Gallery: 17 photos
Joined Dec 2004
Dec 01, 2008 17:49 |  #5
I am not saying that your lens is not soft but the photo you posted has some exposure, white balance and noise problems all of which will make it look soft in itself. To do a good test of sharpness put some good light on your subject.
Bruce_Bird
Dec 01, 2008 18:35 |  #6
queenbee288 wrote in post #6793429 (external link)
... and I though it was just my eyes.. glad someone else saw that in the photo...
- Bruce -
- Langwarrin Victoria -
- Gear List -
single_track
Dec 01, 2008 20:54 |  #7
Agree, what I posted was just a grab shot w/o any PP. Separately, I tested the 24-70 lens on 2 different bodies, well lit and firmly mounted for iso 100 shots. I compared the results against my knowns (17-40, 70-200, 17-85 and 50 1.8). I did not keep these tests shots to post - I should have kept them to show you.
Thanks for you help.
single_track
Dec 01, 2008 21:02 as a reply to  @ single_track's post |  #8
Also, I exported using the save for web in CS4 at low quality which seemed to screw up the quality (noise and funky colors). Still learning.
Jmantyger
Dec 01, 2008 22:46 |  #9
Similar to my 24-70. Sent it to Canon and they found the "mechanical chassis lose" and re-calibrated it. Sent it to them on a Monday and received it back that Friday-sharp as a tack.
5D MKIII, 16-35L f/4 IS, 24-70L II, 70-200L II f/2.8 IS, 100-400L II, 430 EX III
Feedback
single_track
Dec 02, 2008 22:07 as a reply to  @ Jmantyger's post |  #10
Got back tonight after picking up my new 24-70. After returning my soft copy, the store ordered 3 more for me to test. 2 proved to be very sharp while the third seemed to match my original version. This was discovered while I did side by side tests, in the store with my 5d, PC and tripod.
My original was wasted by my 70-200, 17-40, nifty and even my 17-85. My new version holds its own against my 70-200 and is sharper than my 17-40.
A quick shot of my dog, with a 100 percent crop.
I think I will love my brick.
1,749 views & 0 likes for this thread
Latest registered member is dayuan99
813 guests, 228 members online
