Thread started 06 Dec 2008 (Saturday) 05:42
Best underwater P&S?
The_Camera_Poser
Dec 06, 2008 05:42 |  #1
Hi all,
Other than a G9-10, which I can't afford, what would be the best Canon camera for use in snorkling with a underwater housing? Is there anyone that would give superior image quality and have a decently fast lens? Also, would I want to be shooting at higher ISO, and would I need a particular camera that would do better at 200 ISO or higher?
Also, would IS be helpful?
Thanks!
manipula
Dec 06, 2008 06:24 |  #2
Fastest lens on any compact is on the LX3 I think, decent performance at high ISO too.
Also bear witness to the two Olympus models that go under water without housings.
Cheers, Dave.
www.manipula.co.nz (external link) :: Gear list for the nerds (external link) :: flickr (external link) :: ModelMayhem (external link)
:: insert scathing quip here! ::
The_Camera_Poser
Dec 06, 2008 06:34 |  #3
I didn't think the olympus p&s had very good IQ.
I've been interested in the LX3 for other reasons as well-thanks for that.
manipula
Dec 06, 2008 06:50 |  #4
I haven't looked to see if the LX3 has a underwater housing tbh. Though if it does, I expect it to be very good, as the one for the TZ5/15 is very good.
Cheers, Dave.
danpass
Dec 06, 2008 23:36 |  #5
Pretty happy with the SD870
https://photography-on-the.net …php?p=6802343&p​ostcount=2
http://danpass.blogspo​t.com …snorkel-bahamas-reef.html (external link)
Dan
Gallery (external link) | Gear/Feedback
The_Camera_Poser
Dec 07, 2008 04:29 |  #6
they're looking pretty good Dan! Thanks
kja
Dec 07, 2008 17:27 |  #7
I love the Canon A series cameras with the Canon housings. You can stick it in one of the modes or use complete manual, depending on your needs and interest.
Setting your white balance is easy and makes a huge difference.
There are also hacks out there so you can shoot RAW with several A series models.
IMHO, the Canon A series offer the best bang for buck for snorkelling and casual underwater photography.
The SD series are also very good, but you sacrifice control for a smaller form.
Kristin
Jon
Joined Jun 2004
Dec 07, 2008 19:20 |  #8
Well, Kristin, you better stock up on A720s and A590s while you can, since none of the new A series offer M, Tv or Av.
Jon
Cocker Spaniels
kja
Dec 07, 2008 20:09 |  #9
Well, that's a bummer!
Skip the A590, I think that was one that doesn't have a housing. The 570s do and I have a couple of those :)
Kristin
danpass
Dec 07, 2008 20:30 |  #10
kja wrote in post #6832130 (external link)
There is certainly a sacrifice in control. I manually set the camera to ISO400 to force a faster shutter speed.
I had set the print button to manual WB and set it off the sand at the bottom. This created the problem where everything that was shallow would be red.
But at depth it was great :D.
When I didn't have it set manually I merely used autoWB. There is enough range in the JPEG for Lightroom or even most other programs to set a decent WB.
Dan
buckyuk
1 post
Dec 08, 2008 04:47 as a reply to  @ danpass's post |  #11
I would go for the 570, thats what i use and pretty happy wth it.
lottery results (external link)
gnirtS
Dec 08, 2008 10:11 |  #12
Canon powershot range, then get the CHDK hack to enable RAW mode - essential for correcting colour casts underwater. Also means you're not constantly trying to recalibrate a manual white balance whenever you change depth, sun goes behind a cloud and so on - can all be done in PP.
Depending where you're actually going i'd try to keep the ISO at 100 or 200 max - if its somewhere sunny should have no problem with that.
I use an A620 with housing and RAW hack for underwater stuff and its fine.
flickr: http://www.flickr.com/​photos/whitcomberd/ (external link)
http://www.hvsac.co.uk (external link)
1,940 views & 0 likes for this thread, 7 members have posted to it.
652 guests, 124 members online
