Thread started 06 Dec 2008 (Saturday) 19:03
extender or teleconverter
Keflack
Dec 06, 2008 19:03 |  #1
Hi,
I currently have a canon xs 1000D and i was looking into a teleconverter (extender),i have 3 lnses,the 1 that came with it,18-55mm auto & manual focous,a 75-300 canon zoom auto & manual focous,& a 500mm manual focous,my question is,will a manual teleconverter Cozon MC 1.7x extender work with my lenses?? any suggestions??
macroimage
Dec 06, 2008 19:15 |  #2
It might work with your 75-300 in manual focus mode. It would not work with the 18-55 or the 500. The 75-300mm lens would become a 119-510mm f/6.7-9.5 manual focus lens of very low quality. So there is no point to use the extender. Just use your 500mm lens instead.
Photo Gear
Keflack
Dec 06, 2008 19:26 as a reply to  @ macroimage's post |  #3
i was planning on using it for my 500mm lense..the point was to get closer to my subjects and also a man that had been in photography told me that it would deff improve my photo detail especially with the 500...the 500 is manual focous..
macroimage
Dec 06, 2008 19:56 |  #4
Then definately try it out before buying it to see of you like it or if it works at all.
EOS camera bodies usually give an error when using a manual lens on an electronic teleconverter due to a switch in the mount that shows the presence of an electronic lens. The only pictures of a Cozon 1.7x extender that I have seen have the electronic contacts.
What kind of 500mm lens do you have? Remember that a teleconverter isn't magic. It increases the exit angle of the light from the lens. This spreads the image over a larger area and therefore magnifies the faults of your lens.
Make sure you try it before buying it. If it works at all, you still might not like the results.
Photo Gear
Keflack
Dec 06, 2008 19:56 as a reply to  @ macroimage's post |  #5
The converter is a manual
Keflack
Dec 06, 2008 19:59 as a reply to  @ Keflack's post |  #6
i have a rokion 500mm manual focous and the guy that wants to seel it to me is in sweden and i am in canada,he want's to sell it 40 euro that would be 65 canadian...what should i do???? i do know that a piece of tape can be put over the 1st 3 electric contacts on the converter to stop the contact..
nureality
Dec 06, 2008 20:33 |  #7
A 500mm is not a handholdable thing. At least not if you want sharp images. At that focal length the slightest amount of vibration makes focusing difficult to say the least because the image in the viewfinder is jumping around like crazy. Adding a TC to that will simply aggrevate the problem.
Also, bare in mind that the TC will cost you 1.5 to 2 (to sometimes 3) f-stops of light. So, depending on what your maximum aperature of your 500mm lens, add at least 1.5 f-stops to that speed. I'm gonna go out on a limb and guess that your 500mm Manual Mode lens is a f/8 Mirror lens. f/8 + 2-stops = f/16. At f/16 you need A LOT of light, plus in order to shoot a fast enough shutter speed to get a steady shot on a 500mm you need at least 1/500 or faster. 1/500 @ f/16 will only be possible in VERY bright sunlight.
Sorry, but your best bet is to not bother with the teleconverter for this lens.
What will you be shooting with this focal length?
-Alan
Alan "NuReality" Fronshtein
Gear List | PBase |  (external link)flickr (external link)
Lots of Fun, Lots of Laughs, Happy Trigger Finger!
nureality
Dec 06, 2008 20:38 |  #8
another thing to remember, your Rebel XS (1000D) is a 1.6x crop camera. So, your 500mm lens is the equivalent of 800mm on film. You aren't gonna need more than that in any case. Also, if I'm right about your 500mm being a f/8 Mirror lens. They aren't that good to start with.
They are cheap old-tech lenses (made currently, yes), but they aren't very good. They never have been.
-Alan
macroimage
Dec 06, 2008 22:51 |  #9
It would appear that Rokinon has sold several 500mm lenses.
A 500mm f/8 catadioptric (mirror),
a 500mm f/6.3 catadioptric,
a 500mm f/8 refractor telescope often used as a camera lens.
In any of those cases, a teleconverter isn't going to get you any more reach than cropping. Your camera already out-resolves the lens by a lot. Little is gained by magnifying the blur further.
If your pictures don't appear sharp and detailed, the problem is probably with camera shake, poor lighting, or poor post processing.
Photo Gear
Keflack
Dec 07, 2008 05:21 as a reply to  @ macroimage's post |  #10
Hi thanks,
my lense is not a mirror lense and yes the ap is f/8..the problem is,i use a sturdy tripod with my 500mm and also my 75-300mm but no matter what,i can't get that sharp fine detail,so a guy i know in sweden made a offer to sell me his and i have seen some of his photos and they are fantastic,so if i'm using the same equiptment,why are mine not that good??my 500mm lense is much longer than the picture above though..do you think it is a setting messed up in my camera itself?
Keflack
Dec 07, 2008 05:40 as a reply to  @ nureality's post |  #11
Hi,
I was planning on wildlife,yes my 500mm is a manual f/8,it's a high definition lense,and i have a canon 75-300mm lense but i don't have alot of clarity with either 1..why is there not alot of sharpness,in my settings i have the sharpness the whole way up,i shoot in raw/jpeg mode but i don't get that sharpness...
nureality
Dec 07, 2008 08:19 |  #12
its not the camera, its the lens. These lenses are of very low quality hence they are as cheap as they are. They can't deliver super sharp results no matter what setting you use. The limitation is the lens.
nureality
Dec 07, 2008 08:23 |  #13
for your best shot at sharpness you need to shoot even with it tripod-mounted at shutter speeds faster than 1/500, I'd even suggest faster than 1/1000.
Keflack
Dec 07, 2008 08:37 as a reply to  @ nureality's post |  #14
Ok,what lens do you suggest in like the 200 dollar range or a good brand to buy.
Larry ­ Weinman
Dec 07, 2008 09:23 |  #15
Unless you use a teleconverter with the very best lenses that Canon makes ( 300,400,500,600,800mm Supertelephotos) you are going to see image degradation. You will get better results by sticking with what you have and cropping.
7D Mark II 6D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm Mk II 1.4 TCIII 2X TCIII 580EX II 430 EX II MT 24 EX Sigma 150-600
3,061 views & 0 likes for this thread, 6 members have posted to it and it is followed by 2 members.
1163 guests, 121 members online
