Thread started 08 Dec 2008 (Monday) 01:09
PC questions-. viewing files and sizes
azpix
Dec 08, 2008 01:09 |  #1
my HD is filling up.
is there a easy way to view all the files on your pc that aren't associated with a program so i can see what i need to move or delete?
IS there some common filler on here I can delete?
Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
BigBlueDodge
Dec 12, 2008 01:20 |  #2
what do you mean "not associated with a program?. Technically all files are associated with some program or they would not exist.
What OS are you running? If you are running Windows, you can always use the "Disk Cleanup" tool that will search your hard drive and look for files that it thinks you can archive/delete.
David (aka BigBlueDodge)
Gear
Jonathan
Dec 12, 2008 01:39 |  #3
There is a good tool called TreeSize that allows you to view folder structures and their associated sizes. It often helps to show you where most of your space is being used.
However, if you are not ABSOLUTELY sure about what you are doing, take the advice above and just use the build in Disk Cleanup tool. Many files that are not associated with a specific program are system files and you delete those at your peril :-)
"Don't believe everything you read on the Internet" - Winston Churchill
My blog siteexternal link
My Gear List
My Flickrexternal link
azpix
Dec 17, 2008 10:19 |  #4
BigBlueDodge wrote in post #6862596 (external link)
I'm running xp sp2.
I have about 108 gb hard drive that is nearly full. I know about 38gb is photos that I am slowly moving to externals. What I'm trying to figure out is what is taking up the rest of the space.
I have noticed one thing, with light room for example, i have folders for LR 1, LR 2 and now LR 2.2. same with dozens other programs. can i go in a delete the earlier versions?
I've run the xp disk clean up and I have program called iolo that looks for stuff to clean and together the free up tidbit of space here and there. I'm looking for a way to know what is using 65gb of space.
thanks
azpix
Dec 17, 2008 10:20 |  #5
lemminglover wrote in post #6862659 (external link)
thanks. i'll check out treesize.
deadpass
Dec 18, 2008 00:56 |  #6
108GB isn't very much, you should consider getting another hard drive, storage is cheap these days.
a camera
http://www.deadpass.co​m (external link)
azpix
Dec 19, 2008 02:06 |  #7
deadpass wrote in post #6900901 (external link)
good point. Looking at picking up a 1 TB internal. that should solve a lot of problems.
469 views & 0 likes for this thread, 4 members have posted to it.
1788 guests, 119 members online
