Thread started 09 Dec 2008 (Tuesday) 23:11
5D2 Grip?
str8six
Dec 09, 2008 23:11 |  #1
Anybody get the grip for the 5D2 yet? Comments?
Regards, Len B
Zeth
Dec 09, 2008 23:25 |  #2
have one in the mail right now, will post when it arrives.
5D Mark II | 85L | 70-200 2.8 IShttp://www.jasonburtph​otography.com (external link)
fashioneyes
Dec 10, 2008 03:36 |  #3
... I'm waiting on the wireless on ... no news yet ...
1D4, 7D, 5D2 + L lenses
Links: Jepson Photography (external link) / Model Portfolio (external link)
A-Plant BSB Team (external link)
timnosenzo
Dec 10, 2008 05:50 |  #4
fashioneyes wrote in post #6849334 (external link)
B&H has the wireless grips in stock. (external link)
Eyelikedurt
Dec 10, 2008 05:56 as a reply to  @ timnosenzo's post |  #5
Awaiting delivery at my local store. As big as the body is, i still can't shoot comfortably without a grip.
In this house we obey the law of thermodynamics!!
Gear: 5D MKii w/grip | 18-55 Canon | 55-200 Canon(ancient) | 50mm 1.8 Canon | 10-22mm Canon (for sale!)| Sigma 24-70 2.8 EX | 24-105L Canon | 430Ex Speedlite |
www.markandrewphotogra​phy.co.uk (external link)
MikeCaine
Joined Jan 2005
Dec 10, 2008 06:27 |  #6
Eyelikedurt wrote in post #6849581 (external link)
Same here, I hope mine arrives soon
sinitry23
Dec 10, 2008 06:56 |  #7
There's two grips for the 5D II?
What will the wireless one use for? Transferring files to your computer? Does the wireless one have an extra battery?
http://www.william-chang.com/ (external link)
Familiaphoto
Dec 10, 2008 06:59 |  #8
I have the non WiFi grip on the way to me with my 5DII...should have it today. I can let the group know what I find out.
Paul
Blog (external link) | Gear (external link) | Gallery (external link)
Bag Reviews: Domke F-3x | More to come...
str8six
Dec 10, 2008 07:32 |  #9
I had ordered one when I ordered the body but local shops don't know when they will arrive. I was wondering if anybody else had one yet (I got my body about a week after the first one was announced).
I never knew about the wireless one! Is there more information on it somewhere?
Thanks for your replies.
Regards, Len B
timnosenzo
Dec 10, 2008 08:15 |  #10
sinitry23 wrote in post #6849747 (external link)
The wireless grip takes a LP-E6 battery (just one) like the 5D MKII, but the battery in the grip only supplies power to the grip, it does not supply power to the camera.
Here's more detailed info on the grip (Canon makes one for the 40D/50D as well, that is why you see it referenced in here):
Canon WFT-E4A Wireless File Transmitter for 5D Mark II Overview
The new WFT-E4A Wireless Transmitter allows you to connect to wireless and wired LANs, and supports FTP, PTP, and HTTP. Thanks to a connection wizard with broad compatibility, network access is sharply improved. The new WFT-E4A is a premier work tool with expanded capability to link up with external storage media and GPS devices and others.
Compatible cameras: WFT-E4/E4A: EOS 5D Mark II
Feature Highlights
  • Three communications protocols FTP/PTP/HTTP are supported.
  • Connection wizard for setting communications mode preferences, which may be done via camera nu. Wireless access point detection function provided.
  • IEEE802.11g and IEEE802.11b wireless LAN support, with top link speeds of 54Mbps and 11Mbps, respectively.
  • Image file transfer via Ethernet 100Base-TX wired network.
  • The built-in antenna is sealed against dust and water like the EOS DIGITAL SLRs.
  • USB 2.0 Hi-Speed port.
  • WPA-PSK authentication and TKIP encryption for secure data transfer.
  • WFT-E4/E4A and WFT-E3/E3A* support Wi-Fi Protected Setup™.
* Compatible with the EOS 50D only if the WFT-E3/E3A firmware is version 2.0.0 or higher.
Three communication protocols
Canon has raised wireless image file transmitters to a new height by carefully listening to input from professional photographers. The WFT-E4A pack into a compact body the advanced functions that enhance the production workflow in your photography business. It not only responds to various uses and networks but also offers smooth network configuration. It even comes with a USB host function for expanded connectivity.
Image file transfer to server: FTP mode
The WFT-E2/E2A/E3/E3A/E4/E4A makes workflow smooth and efficient by letting you transfer image files to a designated FTP server via wireless/wired LAN. Such capability allows other people to check, select and immediately use the photos you've just taken, regardless of shooting location. Higher transmission speeds mean the WFT-E2/E2A/E3/E3A/E4/E4A is ideal for a wide range of fields, from commercial and news photography to commemorative shooting.
FTP Mode Highlights
  • Easy network set-up through OS server.
  • Automatic transfer of photos the moment they're taken, including the specific image or images you choose.
  • Transfer of images viewed on screen with <SET> button.
  • Transfer with caption function allows registering up to 15 captions with a maximum of 31 characters to be created and attached to an image file.
  • Size and type of data, as well as recording media (CompactFlash, SD Memory card and external storage media) all may be individually selected for automatic transmission when camera is set for media-specific recording in RAW or JPEG, as well as in RAW+JPEG mode.
Remote control of camera: PTP mode
You remotely control your EOS DIGITAL camera via USB connection to a computer with the EOS Utility remote shooting function. The PTP mode of the WFT-E2 / E2A / E3 / E3A now enables remote camera control via wireless/wired LAN plus access to more power and options in studio sessions and fixed-camera shooting. In this mode, of course, all control functions of the EOS Utility, including the shutter, image transfer and folder monitoring, are remotely controlled.
PTP Mode Highlights
  • Easy PC connection with bundled WFT Pairing Software.
  • Focus, aperture and other camera functions can be set from PC while monitoring images on screen.
  • Remote Live View shooting, possible for manual focusing only, enables PC control of functions from zoom out to fine focus, as well as exposure and shutter.
Image browsing on the Web: HTTP mode
One of three data transfer modes, HTTP mode enables remote camera connection while allowing client users to browse and download image data stored on a camera's memory card via Web browser. This mode is compatible with any browser software or OS.
HTTP Mode Highlights
  • Users can check images and download desired image data after choosing one of the media available with the camera (CF/SD/other external media)
  • Access, via log-on names and passwords, can be done simultaneously by up to three users.
sinitry23
Dec 10, 2008 08:30 as a reply to  @ timnosenzo's post |  #11
Thanks for the info!
Familiaphoto
Dec 10, 2008 08:39 |  #12
Great info Tim, thanks.
Paul
Nukey
Joined Nov 2005
Dec 10, 2008 09:18 |  #13
That's obscenely expensive (wireless grip)!
Canon 5D Mark II
24-70 f/2.8L, 70-200 f/2.8L, 430EX
My Photographyexternal link
timnosenzo
Dec 10, 2008 10:09 |  #14
Nukey wrote in post #6850343 (external link)
True, but for studio photographers it has to be a dream.
MarKap77
Dec 10, 2008 10:54 |  #15
When you consider what it does, it really isn't. Now, if all you want is a portrait grip, yeah it is way more dinero than the standard battery grip, but then they are two totally different animals.
Besides, who got into photography to save money? LOL
Mark
My Gear List
"I don't travel to get to work, travel IS my work!
8,751 views & 0 likes for this thread, 23 members have posted to it.
5D2 Grip?
1172 guests, 155 members online
