Thread started 09 Mar 2005 (Wednesday) 10:37
Quick Photoshop Tip (CS Only)
chris.bailey
Joined Jul 2003
Mar 09, 2005 10:37 |  #1
I think this may be a new feature in CS only but you can now do healing and clone tool corrections on a new layer. Just do a Layer>New Layer. Click that layer to make it active and do the healing and cloning on that layer. That makes it easy to click it on and off to see the before and after or to dump that layer if you make a hash of it.
The beauty is you can add more than one layer and try different clones and then just erase or turn off the one you like least.
scottbergerphoto
Joined Jun 2003
Mar 09, 2005 11:30 |  #2
I have started to make virtually all my adjustments on layers. In addition to the advantages you mentioned, you can adjust the intensity of the change by adjusting the opacity of each layer and you have greater control over where in the image or the selection the adjustment is applied by using a layer mask. It's taking me along time to learn CS, but it's a pretty incredible tool.
I suggest Photoshop CS for Digital Photographers by Scott Kelby.
Regards,
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
mapollo
Joined Apr 2004
Mar 09, 2005 13:31 as a reply to  @ scottbergerphoto's post |  #3
If any one is like me and struggling to get this tip to work you need to have "Use all Layers" checked on the options bar.See below......
"Select Use All Layers in the options bar to sample data from all visible layers. Deselect Use All Layers to sample only from the active layer"
Thanks for the great tip...
Canon 20d, BG-e2 , 17-40 F4L , 70-200 F4L , 50mm F1.8 Mk ii, 430ex, Kata R-103, Manfrotto 055XProB & 804RC2
tim
Light Bringer
Mar 09, 2005 14:07 |  #4
Great tip, thanks!
3,430 views & 0 likes for this thread, 4 members have posted to it.
1059 guests, 103 members online
