Hope someone here can help me, I turned on my 400D last night and had no display at all from the rear LCD. If I turn the camera on the green light comes on and stays on even after I switch the camera off. If I turn it on again and switch it off again right away camera will switch off. I have tried taking out both batteries and letting the camera reset and still no display. I have tried three different batteries, different compact flash cards, different lenses all with the same result. The camera was working fine when I put it away about a month ago. The next thing I have been thinking of try is a new 2016 battery. The camera will still take pictures and the lens will focus, flash will work but still no display. Camera is no longer under warranty so I am hoping to see if there is a fix so I don't have to send it back. Depending on the cost I don't know if I would or not as I also have my 40D, but the Rebel probably has less than 2000 clicks on it.
Thanks In Advance
Wayne
