dfuccillo wrote:
I have set my custom function#8 to create a RAW + Large/Fine. I noticed that when I extract the JPEG using Canon's Utility Viewer, its much smaller in size compared to when I take the RAW image and run it through Canon's UV and convert file to a JPEG. Which one would be the best quality?? I would suspect the one converted using Canon UV.
Unlike roses, a jpg is not a jpg is not a jpg. The size of the jpg is related to the compression ratio, the amount of fine detail vs. color field in the photo, and the number and range of colors in the image - as well as a number of more esoteric items. The size difference you see may be compression ratio.
Or - it could be something else! Namely - the 'mess-about' factor. We are often fooled into thinking that because we are shooting digital, each copy is the same as the last. Well - yes - if it is a direct copy. But what if it is a conversion? From one format to another to another. From 1 color space to another. If you take two images - one processed very little and one processed multiple times that include conversion - the former will be the "cleaner" image.
I shoot Raw + Large JPEG so I have a quick & dirty image and one to play with - in case the image is good enough for extracting from Raw, for which I use C1.
Keep in touch!
PJ
www.pjsaine.com
