It's exposed to the left says lightroom, but how is it in your monitors?
MannP Senior Member 430 posts Joined Apr 2007 Location: Sydney, Australia More info | Dec 16, 2008 02:20 | #1 It's exposed to the left says lightroom, but how is it in your monitors? https://photography-on-the.net/forum/showthread.php?t=463218
tfizzle Senior Member 785 posts Joined Oct 2008 More info | Dec 16, 2008 02:23 | #2 exposure looks fine to me. Hair loses detail and is dark. Might be picking up that since it takes up a bit of space. You also lose detail on the right side because of dark shirt and bokeh in the hair = dark
Dec 16, 2008 02:54 | #3 tfizzle wrote in post #6887473 exposure looks fine to me. Hair loses detail and is dark. Might be picking up that since it takes up a bit of space. You also lose detail on the right side because of dark shirt and bokeh in the hair = dark So do you think it's necessary to increase exposure on the hair to get it even across the frame? https://photography-on-the.net/forum/showthread.php?t=463218
tfizzle Senior Member 785 posts Joined Oct 2008 More info | Dec 16, 2008 02:56 | #4 depends if you've lost the data or not. If the shadows can't be recovered you'll just end up with noise.
Dec 16, 2008 03:06 | #5 I tried to tweak the hair but it did come out a bit weird. https://photography-on-the.net/forum/showthread.php?t=463218
tfizzle Senior Member 785 posts Joined Oct 2008 More info | Dec 16, 2008 03:08 | #6 welcome...a picture is only as good as your available light. Processing can help but you need a running start. Keep learning. . .i'm fairly new to photography and I learn something every single day
| Latest registered member is SteveeY 1688 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
