Hi there,
Could someone please explain the difference between setting the flash manally or using FEC? I can set one or the other in my G5 but I don't really understand the difference.
Thanks in advance.
shniks Goldmember 1,041 posts Likes: 1 Joined Jan 2004 Location: Melbourne, Australia More info | Mar 10, 2005 20:49 | #1 Hi there,
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Mar 10, 2005 21:56 | #2 When you set the camera to fire the flash automatically, the camera determines how much power is required from the flash. When it thinks that it's gotten just enough light from the flash, the camera shuts off the flash. However, the camera doesn't always get the flash exposure right. When the subject is dark, the camera will use more flash output and cause the picture to become overexposed. When the subject is too light, the camera will underexpose the picture. ...Leo
kreego Member 109 posts Joined Mar 2004 Location: Paris (Issy-les-Moulineaux) France More info | PacAce wrote: On the other hand, when using the flash in manual mode, the flash will always fire at full power or, if set via the camera or flash, at some fraction of the full power. The flash output is fixed and the camera will not attempt to control the output of the flash. To get a good flash exposure, you have to manually set the appropriate aperture value based on the guide number of the flash for the power selected and the distance from the flash to the subject. This is not something to be attempted by the faint of heart, anyone turned off by math or someone who can't judge distances to save his life. ![]() Leo, your explanation is outstanding in its clarity. I would respectfully disagree with the complexity of using manual flash settings - its a practice I've adopted on a semi-permanent basis with my G5-420EX combination, and its get splendid results. You are right that hashing out the right ratios, especially for studio work, can get a bit mathy, and really requires a dedicated flash meter, but for the vast majority of us creative users, I think the empirical method of dialing in the right amount of flash over two or three shots, works great. Now of course this approach is only possibl with a digital camera, allowing instant feedback on the results of such experiments. But for everyone who's ready to experiment a bit (think slave flashes, diffusers, etc.) manual flash operation is likely to be highly rewarding. From there, operating entirely in M mode is just a click away Canon 5D, 350D and grips
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | kreego wrote: Leo, your explanation is outstanding in its clarity. I would respectfully disagree with the complexity of using manual flash settings - its a practice I've adopted on a semi-permanent basis with my G5-420EX combination, and its get splendid results. You are right that hashing out the right ratios, especially for studio work, can get a bit mathy, and really requires a dedicated flash meter, but for the vast majority of us creative users, I think the empirical method of dialing in the right amount of flash over two or three shots, works great. Now of course this approach is only possibl with a digital camera, allowing instant feedback on the results of such experiments. But for everyone who's ready to experiment a bit (think slave flashes, diffusers, etc.) manual flash operation is likely to be highly rewarding. From there, operating entirely in M mode is just a click away Regards, K PS - if you're ready to take the manual flash compensation plunge, read up on the basics of artificial lighting, because there are quite a few new variables in the mix, which can lead to a fair bit of frustration. Yes, I completely agree with you. My last sentence was made with tongue in cheek (as indicated by the ...Leo
ScottK Member 96 posts Joined Jun 2004 Location: Oceanside, CA, USA More info | kreego wrote: PS - if you're ready to take the manual flash compensation plunge, read up on the basics of artificial lighting, because there are quite a few new variables in the mix, which can lead to a fair bit of frustration. Any suggestions? I've used my 420ex in manual with decent results, but I mostly set aperature based on other considerations (DOF, or 5.6 for sharpness, primarily), then adjust the flash output for the desired effect - over 2 or 3 shots, like you said. If there's a more inteligent way to go about it, I'd love to learn.
kreego Member 109 posts Joined Mar 2004 Location: Paris (Issy-les-Moulineaux) France More info | ScottK wrote: Any suggestions? I've used my 420ex in manual with decent results, but I mostly set aperature based on other considerations (DOF, or 5.6 for sharpness, primarily), then adjust the flash output for the desired effect - over 2 or 3 shots, like you said. If there's a more inteligent way to go about it, I'd love to learn. Scott, here's what I bear in mind when I mix flash and ambiant light. For a given F-stop, the flash power and shutter speed will influence how much light arrives on each part of your scene (flash part, and ambiant part). Now, what you want to work out is whether your scene is going to be dominated by the flash, by ambiant light, or by an even mix of both. Canon 5D, 350D and grips
shniks THREAD STARTER Goldmember 1,041 posts Likes: 1 Joined Jan 2004 Location: Melbourne, Australia More info | PacAce wrote: You can rectify this by using FEC. You can use, for example, an FEC of -2/3 stop when you are shooting very dark subjects so that they don't come out overexposed. Conversely, you can use +2/3 stop when the subject is too light so that it doesn't get underexposed. Thanks for the informative reply, but now I am confused! When the subject is dark wouldn't you use a FEC of +2/3 stop, not -2/3 stop? Maybe this is where I am going wrong?
kreego Member 109 posts Joined Mar 2004 Location: Paris (Issy-les-Moulineaux) France More info | shniks wrote: Thanks for the informative reply, but now I am confused! When the subject is dark wouldn't you use a FEC of +2/3 stop, not -2/3 stop? Maybe this is where I am going wrong? My dilemma is that whenever I am at a wedding I try to take photos inside the church or reception, and they are always too dark. Even when I set the aperture as open as possible, and I don't like to increase ISO too much. I am trying to figure out which is best to use, FEC set at +2/3 (or -2/3 as you said above?) or manual flash set at maximum, keeping in mind that the aperture stays fixed. Do I just need to go out and buy a 420ex, because the on board flash is too weak? Hi shniks, Canon 5D, 350D and grips
| Latest registered member was a spammer, and banned as such! 1792 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
