Almost every time I go to one of the 200's to adjust one of the buttons, the flash fires. It happens a moment after I finish pressing whichever button. It's annoying and wasteful. Is this a flaw in the flash unit, or is it normal?
Stefan
StefanA "The D is supposed to be where the S is!" More info | Dec 16, 2008 10:24 | #1 Almost every time I go to one of the 200's to adjust one of the buttons, the flash fires. It happens a moment after I finish pressing whichever button. It's annoying and wasteful. Is this a flaw in the flash unit, or is it normal? 80D, Canon 17-55mm f/2.8, Canon 18-135mm f/3.5-5.6, Canon 50mm f/1.4, Canon 70-200mm F/4L,Tokina 11-16 f/2.8, Canon 100-400 f/4.5-5.6, Kenko 1.4 TC, Canon 580 exII Speedlite, ebay wireless trigger, Genesis 3 light kit
BigBlueDodge Goldmember 3,726 posts Joined May 2005 Location: Lonestar State More info | Dec 16, 2008 10:26 | #2 mine does the same thing, and I think it's normal. David (aka BigBlueDodge)
D_CeLiRaToR Member 220 posts Likes: 1 Joined Aug 2007 Location: Racine, WI More info | Dec 16, 2008 10:30 | #3 i think it's to clear the memory of your last setting. -Mike
Guapo Senior Member 548 posts Joined Jan 2005 Location: Dallas, TX More info | The only time mine does it is when I lower the power level, and the flash "dumps" the excess energy. Otherwise, I don't get any random fires. - Steven
Peacefield Goldmember 4,023 posts Likes: 2 Joined Jul 2008 Location: NJ More info | Dec 16, 2008 10:32 | #5 I have the same lights. What I assume you're talking about is adjusting the power setting. If the power setting is 45 and you want to take it down to 35, the light has already charged itself to 45. It needs to discharge that power and reset itself to the lesser setting. That's the only time it should be happening. And yes, obnoxious, but necessary. Just close your eyes or look away when your done reducing power. Robert Wayne Photography
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Dec 16, 2008 10:47 | #6 ABs don't do this. Fuji XT-1, 18-55mm
545iBMW Senior Member 475 posts Likes: 3 Joined Apr 2008 More info | Dec 16, 2008 11:26 | #7 bobbyz wrote in post #6889143 ABs don't do this. From what I read somewhere, ABs don't do this but the first shot after adjusting down the power, you will still get the same power level as the previous setting (i.e. from 3/4 to 1/4, the first shot will still give 3/4 and succeeding shots will then be set to 1/4). I think I wouldn't want that since I would get an overexposed shot every time I lower my power setting.
jdpence Senior Member 584 posts Joined Jul 2008 Location: Atlanta, GA More info | Dec 16, 2008 12:00 | #8 545iBMW wrote in post #6889361 From what I read somewhere, ABs don't do this but the first shot after adjusting down the power, you will still get the same power level as the previous setting (i.e. from 3/4 to 1/4, the first shot will still give 3/4 and succeeding shots will then be set to 1/4). I think I wouldn't want that since I would get an overexposed shot every time I lower my power setting. Basically, with the AB, you need to "dump" the extra power manually everytime you lower down the power and the Genesis does it automatically by dumping through a flash. That is not accurate. After reducing the power on my AB's the "dump" light comes on as the extra energy is discharged internally. This happens without firing the flash tube and the next shot will be at whatever power setting you have changed it to. Jeremy
545iBMW Senior Member 475 posts Likes: 3 Joined Apr 2008 More info | Dec 16, 2008 12:04 | #9 jdpence wrote in post #6889534 That is not accurate. After reducing the power on my AB's the "dump" light comes on as the extra energy is discharged internally. This happens without firing the flash tube and the next shot will be at whatever power setting you have changed it to. Well, I'm just sharing what I read.
eduardofrances Senior Member 679 posts Joined Oct 2006 More info | Dec 16, 2008 12:06 | #10 Stefan A wrote in post #6889027 Almost every time I go to one of the 200's to adjust one of the buttons, the flash fires. It happens a moment after I finish pressing whichever button. It's annoying and wasteful. Is this a flaw in the flash unit, or is it normal? Stefan If it happens when you are lowering the output power it is perfectly normal, it is a function called "auto dump" which means the monolight is dumping the excess of power it so the monolight is ready to shoot at the power output you selected. http://flickr.com/photos/eduardofrances/
Dec 16, 2008 12:13 | #11 Thanks everyone. I will go home and make sure it only happens when lowering power. I hadn't noticed that. 80D, Canon 17-55mm f/2.8, Canon 18-135mm f/3.5-5.6, Canon 50mm f/1.4, Canon 70-200mm F/4L,Tokina 11-16 f/2.8, Canon 100-400 f/4.5-5.6, Kenko 1.4 TC, Canon 580 exII Speedlite, ebay wireless trigger, Genesis 3 light kit
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Dec 16, 2008 12:39 | #12 jdpence wrote in post #6889534 That is not accurate. After reducing the power on my AB's the "dump" light comes on as the extra energy is discharged internally. This happens without firing the flash tube and the next shot will be at whatever power setting you have changed it to. 545iBMW wrote in post #6889560 Well, I'm just sharing what I read. I will try that with my ABR800 and measure with a light meter. The ABs do have a auto dump feature which allows the strobe to discharge to the required level without the need to fire off the strobe. However, if you can't wait the second or two for the excess energy to be discharged automatically, you can fire the strobe yourself to dump it and then wait a second or two for it to recharge. ...Leo
viet Goldmember 1,019 posts Joined Jul 2007 More info | Dec 16, 2008 15:21 | #13 The head was just trying to dump excess power when you decrease the power. If you adjust your power up, I don't believe this will happen. This is a bit annoying, but I'd take that over re-metering after every adjustment anyday.
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Dec 16, 2008 19:37 | #14 viet wrote in post #6890708 The head was just trying to dump excess power when you decrease the power. If you adjust your power up, I don't believe this will happen. This is a bit annoying, but I'd take that over re-metering after every adjustment anyday. I'm not sure I understand. You would have to meter anyway after every adjustment, no? Or do you just adjust the camera setting by the same Ev amount you adjusted the light setting? ...Leo
viet Goldmember 1,019 posts Joined Jul 2007 More info | Dec 16, 2008 22:04 | #15 PacAce wrote in post #6892123 I'm not sure I understand. You would have to meter anyway after every adjustment, no? Or do you just adjust the camera setting by the same Ev amount you adjusted the light setting? What I meant was that Genesis is very consistent in its power adjustment, and it really helps with the digital dial instead of analog.
| Latest registered member is semonsters 1465 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
