Thread started 17 Dec 2008 (Wednesday) 07:26
Sekonic to trigger camera?
DozerLYP
Dec 17, 2008 07:26 |  #1
I have a question. If I put the PW on the camera and an other one on the flash, can I trigger the camera and the flash with the Sekonic L-358?
in other words, can I use the Sekonic as a remote to realest the shutter?
Home Improvement
Custom Brushes!
PacAce
Joined Feb 2003
Dec 17, 2008 07:56 |  #2
Yes, you can assuming that you have the proper remote release cable for the camera. You'll need to set the PW unit on the camera, which I'm assuming is a Plus II, to relay mode. The Sekonic then needs to be set to the same channel as the PW unit on the camera. The PW unit connected to the flash, however, needs to be set to a channel one higher than the channel set on the PW unit on the camera. If all the PW units are set to the same channel, the flash will not properly sync with the camera.
...Leo
DozerLYP
Dec 17, 2008 08:54 |  #3
awesome, thanks.
Home Improvement
Custom Brushes!
1,118 views & 0 likes for this thread, 2 members have posted to it.
897 guests, 120 members online
