Thread started 17 Dec 2008 (Wednesday) 12:03
I can not understand about Sekonic L 358.
Gedi
Dec 17, 2008 12:03 |  #1
I bought a new light meter Sekonic L-358
I used it, and this is what he left me:
Help me...
Canon 5D Mark III I Canon EF 35mm f/1.4L I Canon EF 50mm f/1.2L I Canon EF 85mm f/1.2L II USM I Canon EF 24-70mm f/2.8L II I Speedlite 600EX-RT I Flickr (external link)
Canon 30D I Canon EF-S 17-85mm F/4-5.6 IS I Sigma 50mm 1.4 I Sigma 18-35mm F1.8 DC HSM I Canon 580EX II Speedlite I Tamron AF 28-75mm f/2.8 I
FlyingPhotog
Cream of the "Prop"
Dec 17, 2008 12:05 |  #2
Can't really tell from the images but if the shutter speed it calls for is 1/4 second, you either need a lot more light, a wider aperture opening, higher ISO or a tripod and cable release.
1/4 second is going to be nearly impossible to hand hold.
Jay
cdifoto
Don't get pissy with me
Dec 17, 2008 12:07 |  #3
Gedi wrote in post #6896398 (external link)
Help me...
I don't see anything wrong. You're trying to use a low ISO and relatively small aperture in the dark...
The exposure looks right, so the meter is functioning fine.
hawkeye60
Dec 17, 2008 12:09 |  #4
cdifoto wrote in post #6896432 (external link)
...or use a tripod.
It's a lens not a lense!
The truest test of character is what you do when you think no one is looking.
Benji
Dec 17, 2008 12:35 |  #5
Don't use 1/4 of a second shutter speed unless you are using a tripod. When using flash the shutter speed is basically of no consequence unless you are outdoors. I usually use around 125 for my shutter speed when shooting in the camera room.
Tha apple is properly exposed but OOF. I'm guessing the AF missed.
Benji
Gedi
Dec 17, 2008 12:51 |  #6
You are right, but there is another example.
I have pictures without the aid of light meter is fine.
Why Sekonic L- 358 shows on the other?
Speed Shutter 1 / 13
F-Stop 5.0
ISO 100
cdifoto
Dec 17, 2008 12:57 |  #7
That shot is way underexposed.
A meter is designed to analyze the light falling on the subject & give you settings for proper exposure. It's NOT designed to do the impossible - ie give you settings that are magically handholdable or shake-free.
1/13 is slightly more handholdable than 1/4 but I can still see shake. Under those same conditions, setting the meter to f/5 should give you a reading of 1/5 which is still not holdable.
If you want to use a small aperture & ISO100 and still handhold it, you're gonna have to add more light. Period.
Gedi
Dec 17, 2008 13:31 |  #8
cdifoto wrote in post #6896752 (external link)
Thanks for the information. I'm still learning about it.
Titus213
Dec 17, 2008 17:18 |  #9
Bump the ISO to 400 or even 800. It should solve the shutter speed problem.
Dave
Perspiring photographer.
Papa ­ Carlo
Dec 17, 2008 20:27 |  #10
You should realize a lightmeter is not going to take good pictures for you.
In the image you show you have a very good exposure. But there is much more to a good photo than a correct exposure and your example is a good illustration why.
I know it might sound offensive but try getting some good book about basics of photography. You'll save yourself a lot of time and frustration.
Benji
Dec 18, 2008 07:46 |  #11
It appears from the last image you posted that you have the meter set for ambient light and not flash. My above response was for flash. Are you asking about flash or ambient ?
Benji
Gedi
Dec 18, 2008 09:47 |  #12
Benji wrote in post #6901817 (external link)
Benji
I asked about the ambient.
Gedi
Dec 18, 2008 10:01 |  #13
Titus213 wrote in post #6898279 (external link)
Right, I do not want to have a lot of noise. Thanks.
suyenfung
Dec 18, 2008 10:07 |  #14
more light!
cleveland ohio wedding photographer (external link) | gear
Bobster
Dec 18, 2008 10:19 |  #15
lots more light, or get a tripod and use a shutter release
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
DIY Monitor Hood (external link) | Gear | Tweet (external link) | Insta (external link) | FoCal 2 (external link)| Ultimate RAW Editor (external link)
3,686 views & 0 likes for this thread
Latest registered member is KellyLaundromat
375 guests, 263 members online
