Hi everybody, does anyone have any experience using a 1.4 converter with a 28-75mm Tamron Thanks,
Thumbsup
Dec 18, 2008 10:54 | #1 Hi everybody, does anyone have any experience using a 1.4 converter with a 28-75mm Tamron Thanks,
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Dec 18, 2008 11:06 | #2 If someone hasn't already done testing, I have both of the items in question, and can try to perform some tests this weekend. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Dec 18, 2008 11:08 | #3 TCs are not really meant for wide and/or zooms. I wouldn't expect much. GEAR LIST
FilthyMcNasty Member 74 posts Joined Oct 2008 More info | Dec 18, 2008 13:41 | #4 gasrocks wrote in post #6902773 TCs are not really meant for wide and/or zooms. I wouldn't expect much. Kenko Pro 300 works perfectly with my EF 24-105.
ultrabigal Member 98 posts Joined Oct 2007 Location: United States More info | Dec 18, 2008 15:50 | #5 Wilt wrote in post #6902760 If someone hasn't already done testing, I have both of the items in question, and can try to perform some tests this weekend. That would be great let me know Thanks,
nureality Goldmember 3,611 posts Likes: 1 Joined Jan 2008 More info | Dec 18, 2008 16:03 | #6 Filthy McNasty wrote in post #6903610 Kenko Pro 300 works perfectly with my EF 24-105. you mounted a 24-105L to a 3X teleconverter? Alan "NuReality" Fronshtein
nureality Goldmember 3,611 posts Likes: 1 Joined Jan 2008 More info | Dec 18, 2008 16:14 | #7 Thumbsup wrote in post #6902697 Hi everybody, does anyone have any experience using a 1.4 converter with a 28-75mm Tamron Thanks, Thumbsup It should work, mechanically speaking. But given the focal range you're looking at, you'd really be better off just cropping. There is bound to be IQ loss. Given that the Tammy is f/2.8 the 1-stop of loss in light makes it an effective f/4. Which is still usable. Alan "NuReality" Fronshtein
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Dec 18, 2008 16:59 | #8 The larger issue has already been declared...that a teleconvertor was designed for use with a 'telephoto' optical construction. So the Tammy would be fairly questionable, at least in theory, in the 28-50mm range, and somewhat questionable in the 50-75mm range for reasonable results. I have used a teleconvertor on a 'normal' in the past, but that was in my youth and before digital made measurebation so easy to do! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
FilthyMcNasty Member 74 posts Joined Oct 2008 More info | Dec 18, 2008 18:29 | #9 nureality wrote in post #6904424 you mounted a 24-105L to a 3X teleconverter? One question: Why????!?!?!?!? f/4 + 3-stops = f/16!
Katzer1 Senior Member 535 posts Joined Nov 2006 More info | Dec 18, 2008 19:43 | #10 Though in Hebrew and in Nikon, that lens was tested here and this is with a 2X tc Erez Erez Katz, www.pbase.com/katzer
Jman13 Cream of the Crop 5,567 posts Likes: 164 Joined Dec 2005 Location: Columbus, OH More info | Dec 18, 2008 19:56 | #11 It wouldn't matter if your TC was a reporting one or not with the Tammy 28-75, since the lens doesn't have TC contacts. For instance, my Kenko Pro 1.4x (which IS a reporting TC), reports wonderfully on my 70-200L, my 200L and my Sigma 150. It didn't report at all with my drainpipe, nor on any other lens I own, as they don't have the extra 3 pins to report to the TC. Jordan Steele - http://www.jsteelephotos.com
| Latest registered member is Niagara Wedding Photographer 1344 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
