Thread started 18 Dec 2008 (Thursday) 16:59
Helllpppp pleaseeee!!!!
premierxp
Dec 18, 2008 16:59 |  #1
Hello, does anybody know how can I create the white line (which fade to the right side only) in the picture below?
http://img252.imagesha​ck.us/img252/922/photo​rv6.jpg (external link)
I spend hours trying to create that line using the Pen tool in Photoshop and stroke it but fail
IMAGE: http://photocamel.com/forum/images/smilies/sad.gif
. How can I create the line and have the color only fade to one side? Please kindly show me the steps to recreate that line. Thank you very much.
René ­ Damkot
Dec 18, 2008 17:51 |  #2
Something like this might be a start:
Use a Vector mask instead of a path:
IMAGE: http://img.skitch.com/20081218-dptg8dqs9wgjmyneh2m6r6bj3t.jpg
IMAGE: http://img.skitch.com/20081218-rn5xisqkeyr4c69smhqt9jnfqj.jpg
Note that the "Fill" on the black layer (with the stroke) is set to 0.
I think in your example, a copy of the BG image was used instead, with a blur added, and the fill set higher (to taste, depending on the blur).
The white layer under the red is just that: A white layer with a mask.
You'll probably need to convert the "stroke" to pixels to give it the "motion blur", and use a variation on the vector shape for the second "twirl".
Also, there probably are about 10 more ways of doing this ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Lowner
"I'm the original idiot"
Dec 18, 2008 18:11 as a reply to  @ René Damkot's post |  #3
I've just played with your question while an A3+ print was "baking". My solution is nowhere near as elegant as Rene's but it gets the job done.
I created a seperate layer to work on, then using the elipse tool, created a series of curves that copied your example. This I then "stroked" with white to a width of (in my example) 50 pixels and deleted any junk.
After that I just used a soft brush to erase one side of the stroked line and faded the whole layer so the background was visible through it.
As I said not elegant!
The beauty and the frustration of Photoshop is that every problem has twenty different ways of solving it.
Richard
premierxp
Dec 18, 2008 18:12 |  #4
Thanks a lot for your time.
1,238 views & 0 likes for this thread, 3 members have posted to it.
Latest registered member is RawBytes
1495 guests, 163 members online
