Thread started 19 Dec 2008 (Friday) 10:36
Split prism focus screen.
Mark1
Dec 19, 2008 10:36 |  #1
Has anybody installed the split prism focus screen in their camera. This is the only thing I miss from the film days. It took a long time for me to get used to not having it there. But lately I have seen they make them for the EOS. I am about to get it for my 50D. Just wondering if anybody had used them.
And double checking... The 40D and 50D are the same screen, right?
The 2 I found...
http://haodascreen.com​/CanonDSLR.aspx (external link)
http://www.katzeyeopti​cs.com …ing-Screen--prod_40D.html (external link)
Wilt
Dec 19, 2008 10:56 |  #2
The fundamental problem is that Canon does not offer one. So that leaves aftermarket third party products, and these suffer from the problem that there is not a CFn setting in the camera which would compensate the metering sufficiently to be accurate under all circumstances, regardless of metering mode (spot, partial, etc) and max lens aperture (f/2.8 vs. f/5.6). If you are someone who puts the camera into Evaluative mode only, it might be OK, but if you use Spot mode you're hosed.
Mark1
Dec 19, 2008 11:04 |  #3
I have read that as well. Spot metering is totally gone with them. But I almost never spot meter. I mostly do use evaluative, then judge for myself the subject/surroundings ratio to get an exposure. And since this is a new body, I will just have to get used to the metering difference. Problem...Definatley. But I think its not to bad of one. Unless you keep in in auto all the time.
Wilt
Dec 19, 2008 11:10 |  #4
The other thing to consider is if you like to shoot with longer FL lenses and/or with slower aperture lenses...the split prism 'blacks out' half of itself, becoming useless.
Mark1
Dec 19, 2008 11:12 |  #5
I think my old cameras did that as well. The screen takes less than a minute to change. So I will have to keep the OEM in the bag.
virus
Dec 19, 2008 11:16 |  #6
I've used Hoada's split prism in my 350D and i love it..
my AF lights were screwed from before so the screen has been a big help
as far as metering, etc.. i just shoot images, if it looks good i work with it
argyle
Dec 20, 2008 06:47 as a reply to  @ virus's post |  #7
You need to consider something else as well...variations in screen tolerances (especially if going to a 3rd party type), *may* cause focusing issues at large apertures when using MF. I shoot a lot of MF alternate lenses on my 5D (Zeiss, Leica, Oly, etc) and swapped out the stock screen for the Ee-S screen. After doing so, I had a somewhat difficult time getting accurate MF at fairly large apertures. I ended up having to buy a set of focus screen shims from Canon and adjust the screen for MF through trial and error. Now it's spot-on. Several folks that I know that have been using Katz-Eye screens had to do the same. Just something to consider if you plan on doing a lot of MF shooting.
nadtz
Dec 20, 2008 15:32 |  #8
Now that you have been told the negatives, I installed a prism screen on my 350D and loved it. It took a bit of tweaking to get it seated perfect, and metering changed by a bit (I think it was 1/3 or 1/2 stop) but once I got used to it in there I never thought about takingit out. It was very useful for how I shoot, and as the camera in question had no spot meter anyway that wasn't an issue. All my lenses were 2.8 or better as well, blackout was no problem.
The larger VF of my 30D resolved most of my MF problems and I never did install one on that camera, but there was still the occasional time I missed it when manual focusing (especially in low light).
Wilt
Dec 21, 2008 10:57 |  #9
nadtz wrote in post #6916279 (external link)
It was very useful for how I shoot, and as the camera in question had no spot meter anyway that wasn't an issue. .
Be aware that the metering error that comes to Spot with these aftermarket screens will also affect Partial.
donaldjl
Dec 21, 2008 16:13 as a reply to  @ Wilt's post |  #10
Is the metering error equivalent, or is it lessened by the slightly larger metering area?
"And when he came to the place where the Wild Things are they roared their terrible roars and gnashed their terrible teeth and rolled their terrible eyes and showed their terrible claws..."
Wilt
Dec 21, 2008 18:40 |  #11
donaldjl wrote in post #6921791 (external link)
I couldn't say...usually those to buy these focusing screens only use Evaluative or Center weighted! There have been reports of 2-3 EV error in metering with Spot, but not any published analyses of Partial vs. Spot comparison in degree of error with these screeens.
3,350 views & 0 likes for this thread, 6 members have posted to it.
1067 guests, 104 members online
