drevilsmom wrote in post #6918061
I'll give it a try at ISO 800. However, at around 50mm, my lowest f stop will be at 5.6. Will that allow for enough light?
If you're exposing for 4 or 5 minutes then that will be ample.
So far, I know I want a wireless remote and nifty fifty as my first prime. I also need a good camera bag. Wouldn't mind a good grip either! Man this stuff gets expensive, and I have barely even scratched the surface on what I want!
You've barely even scratched the surface when it comes to astrophotography either. This mount might work out nicely, but then you'll be wanting more lenses or some scopes, filters, dew-heaters, guiding scopes, an Astro-Tent or observatory...the list goes on.
Going back to exposure lengths, you might find it's better, if you want to expose for 20 or 30 minutes, or hours, to stack lots of shorter exposures together. If you find you can gather enough light in 5-minutes for example, then stack six of these together, (along with dark and flat frames), rather than expose for a single 30-minute exposure. I think you'll probably find the results are better, plus you spread out the points of failure - if something major goes wrong, (power-failure to the mount, camera-battery runs out, clouds appear), you'll likely still have some good frames to work with, rather than losing the only one.
