I'll do some more experimentation later today after i get back from running some errands. i think i can probably just fix this issue by shooting in raw and balancing it out with lightroom, but it'd be nice to recreate what ETTL is doing to give the picture the warmth that the 2nd picture is sorely missing.
in the meantime, if you're interested in the exif data, here it is. thanks for the feedback!
first picture:
File name: IMG_9652.JPG
File size: 2106603 bytes (3072x2048, 2.7bpp, 9x)
EXIF Summary: 1/90s f/4.0 ISO200 40mm (35mm eq:64mm)
Camera-Specific Properties:
Equipment Make: Canon
Camera Model: Canon EOS 10D
Maximum Lens Aperture: f/4.0
Sensing Method: One-Chip Color Area
Lens Size: 24.00 - 105.00 mm
Firmware Version: Firmware Version 2.0.1
Serial Number: 1220402605
Owner Name: Gerald Gongon
Image-Specific Properties:
Image Orientation: Top, Left-Hand
Horizontal Resolution: 180 dpi
Vertical Resolution: 180 dpi
Image Created: 2008:12:20 23:36:52
Exposure Time: 1/90 sec
F-Number: f/4.0
ISO Speed Rating: 200
Exposure Bias: 0 EV
Flash: Flash, Compulsory, Red-Eye Reduce
Focal Length: 40.00 mm
Color Space Information: sRGB
Image Width: 3072
Image Height: 2048
Rendering: Normal
Exposure Mode: Manual
Scene Capture Type: Standard
Focus Type: Auto
Metering Mode: Evaluative
Sharpness: Normal
Saturation: Normal
Contrast: Normal
Shooting Mode: Manual
Image Size: Large
Focus Mode: AI Focus
Drive Mode: Continuous
Flash Mode: Red-Eye Reduction (On)
Compression Setting: Fine
Macro Mode: Unknown
Subject Distance: 0.091 m
Flash Bias: 1.00 EV
White Balance: Auto
Exposure Compensation: 3
Sensor ISO Speed: 192
Image Number: 396-9652
Other Properties:
Resolution Unit: i
Chrominance Comp Positioning: Centered
Exif IFD Pointer: 196
Compression Scheme: JPEG Compression (Thumbnail)
Resolution Unit: i
Offset to JPEG SOI: 2548
Bytes of JPEG Data: 6656
Exif Version: 2.21
Image Generated: 2008:12:20 23:36:52
Image Digitized: 2008:12:20 23:36:52
Meaning of Each Comp: Unknown
Image Compression Mode: 3
Shutter Speed: 1/90 sec
Metering Mode: Pattern
Focal Plane Horiz Resolution: 3443 dpi
Focal Plane Vert Resolution: 3442 dpi
Focal Plane Res Unit: i
File Source: Digital Still Camera
White Balance: Auto
Base Zoom Resolution: 3072
Zoomed Resolution: 3072
ISO Speed Rating: Unknown
Digital Zoom: None
Self-Timer Length: 0 sec
Canon Tag1 Length: 92
Sequence Number: 0
Canon Tag4 Length: 66
Actuation Counter: 0
Actuation Multiplier: 0
Canon Tag93 Length: 18
Image Type: IMG:EOS 10D JPEG
Custom Function: Lens AF stop button - Operate AF
Custom Function: Safety shift in Av or Tv - Enabled
Custom Function: Shutter curtain sync - 1st-Curtain Sync
Custom Function: Fill flash auto reduction - Enabled
Custom Function: Assist button function - Select HP (while pressing)
Custom Function: Mirror lockup - Disabled
Custom Function: Menu button display position - Previous
Custom Function: Superimposed display - On
Custom Function: AEB sequence/auto cancellation - -,0,+/Enabled
Custom Function: RAW+JPEG recording - RAW+Large/Fine
Custom Function: AF point registration - Center
Custom Function: Exposure level increments - 1/2 Stop
Custom Function: AF-assist beam/Flash firing - Only Ext. Flash Emits/Fires
Custom Function: Shutter button/AE lock button - AF/AF Lock, No AE Lock
Custom Function: Flash sync speed in Av mode - Auto
Custom Function: Shutter release w/o CF card - No
Custom Function: SET button function when shooting - Change Parameters
second picture:
File name: IMG_9651.JPG
File size: 1700480 bytes (3072x2048, 2.2bpp, 11x)
Image Created: 2008:12:20 23:36:41
F-Number: f/4.0
Exposure Bias: 0 EV
Image Width: 3072
Image Height: 2048
Rendering: Normal
Focus Type: Auto
Sharpness: Normal
Saturation: Normal
Contrast: Normal
Image Size: Large
Macro Mode: Unknown
Subject Distance: 0.084 m
White Balance: Auto
Image Number: 396-9651
Other Properties:
Resolution Unit: i
Resolution Unit: i
Bytes of JPEG Data: 5632
Exif Version: 2.21
Image Generated: 2008:12:20 23:36:41
Image Digitized: 2008:12:20 23:36:41
White Balance: Auto
Digital Zoom: None
Flash Bias: 0.00 EV
Sequence Number: 0
