Thread started 22 Dec 2008 (Monday) 19:08
Caution: 5D mkii and focusing screen install!
syntrix
Dec 22, 2008 19:08 |  #1
Just be careful if you are used to a 5D or 40/50D screen swap. The mechanism is a little/deceptive on the full lock position.
If you think the screen is locked in place it might have a little more to go.
* Remember how it looks before removing the standard screen
* Follow the directions and make sure you give it that extra push it make sure it locks.
* Adjust your custom function for the screen.
After the intial push in/lock, it looks like it might be set. I used the supplied tool tab and lifted the metal clip a little more and just rotated to put a little pressure on the screen, and whattaya know, it had another 1/2 mm or so to go in! Yay EGD Screen!
That is all!
moew!!!!!
garrykolb
Dec 22, 2008 19:41 |  #2
That screen looks quite interesting. I can't find any description of what each set of lines crops to. Can you share?
Retired in The Villages, Florida and having fun with my Sony RX10IV
buto
Dec 22, 2008 19:53 |  #3
the focusing screens do not alter metering does it?
John
http://www.flickr.com/​photos/butohairs (external link)
syntrix
Dec 22, 2008 19:57 |  #4
buto wrote in post #6929626 (external link)
They do! That's why there is a built-in setup (custom fuction) for the canon screens. I'm just used to the grid screens and noticed this, so I thought I'd share.
moew!!!!!
jacuff
Dec 25, 2008 10:42 |  #5
Cool, was hoping I'd get the focusing screens for Christmas, but ended up getting a Think Tank Airport International, so I'm happy. Since the standard screen seems to bleed on the top focusing point (12 o'clock position), does the grid screen also do that?
Gear, Feedback (eBay (external link)), Web (external link), Blog (external link), FB (external link), Twitter (external link)
Hermeto
Dec 25, 2008 11:17 |  #6
jacuff wrote in post #6943319 (external link)
I can tell you only for 40D: yes, it does.
No big deal in my books..
importhunnie
Dec 25, 2008 13:37 |  #7
yeah after changing to the grid screen the focus point still has a bleed.
EOS 1DsIII 1DIII 6D
16-35 II 24L II 50L 85L 70 - 200 2.8II 580EX II
RRS BH-25 GT3541LS M10 JrX 285HV SB28x4 L-758DR
domke J1 TT change up/modular Elinchrom quadra ranger RX
www.josephtamayophoto.​zenfolio.com (external link)
Sfordphoto
Dec 25, 2008 16:53 |  #8
is this a common problem on 5dmk2? that the top focusing point bleeds?
Gear
syntrix
Dec 25, 2008 16:57 |  #9
Sfordphoto wrote in post #6944430 (external link)
adding the grid screen will cause slight light bleed to other AF points on AF confirmation.
I'm over it already, it's not a big deal.
moew!!!!!
jacuff
Dec 25, 2008 17:39 |  #10
It's actually common on lots of camera bodies. It's absolutely not a big deal because it doesn't actually affect the focusing any. Some people blow things out of proportion and it appears this is one of those things. I probably use the center point about 90% of the time I'm shooting with the 5D Mark II.
Nikolas
Dec 25, 2008 18:41 |  #11
It is common on my 300D and my 20D, it's just the led's are too bright imho.
Canon 5D2 20D & 300D 50mm f1.8 mk 2, 24-105 f4 IS L
Tokina 12-24 f4
ATX PRO, 400mm f5.6 ATX apo
Sigma 28-70mm f2.8
EX DG, 120-300mm f2.8 EX DG
Tamron SP pro TC 1.4 and KENKO 2x teleplus pro 300DG and lots of m42 lenses
AdamJ
Dec 25, 2008 22:35 |  #12
I also experienced the same when putting the Eg-D in, I thought it was latched closed, but it had a little bit further to go!
-AdamJ
4,877 views & 0 likes for this thread, 9 members have posted to it.
1650 guests, 137 members online
