Thread started 24 Dec 2008 (Wednesday) 10:05
70-200 2.8 wont AF sometimes
Nick ­ Pro
Dec 24, 2008 10:05 |  #1
I was using my 70-200 last night in some cold temperatures (20 F) And when I got home and tried to use it, it wouldn't AF. This has happened before, and when it has, I took the lens off, cleaned the contacts and put it back on, and it worked fine. Does anyone else have this problem.
CAL ­ Imagery
Dec 24, 2008 10:38 |  #2
Did condensation get in it? When going inside after freezing temperatures, one ought to put the lens(es) and body into plastic bags or the like to keep condensation from the equipment.
Christian
S.Horton
Dec 24, 2008 11:03 |  #3
When moving the camera directly from extreme cold to a heated area, I place the camera and lens into a plastic bag first so that condensation is on the bag, not the gear.
Sam - TF Says Ishmael
:cool:
Nick ­ Pro
Dec 24, 2008 11:13 |  #4
The AF does work now, And this happened in the summer as well.
As for condensation, it went from a backpack to a cold car which gradually warmed up, so I think it should be fine. Right?
gasrocks
Dec 24, 2008 12:36 |  #5
You'll have to try that lens on another body to see if it is the lens or your camera at fault.
sherman111
Dec 24, 2008 14:27 |  #6
Yes I have had a similar problem but I put it down to the cold weather, moving from very cold to very warm conditions. The lens soon recovers, I just make sure I bag it now when moving back to a warm environment.
Sherman
Cameras 40D | G9
L Lens 16-35 f2.8L | 24-70 f2.8L | 70-200 f2.8L IS | 100-400 L IS | EF Lens 50mm f1.4 | 28-135 f3.5 | EFS 10-20 3.5-4.5 IS | 17-85 4-5.6 IS
Other stuff 580 EX | 430EX | ST-E2 | 3 x tt5's
bobbyz
Dec 24, 2008 14:46 |  #7
Maybe you are under the MFD of the lens.
When I bought (used) 70-200mmf 2.8 non IS, I was worried as I had AF problems. Turned out MFD of the non IS is worse than the MFD of the IS version.
Fuji XT-1, 18-55mm
Nick ­ Pro
Dec 24, 2008 16:04 |  #8
bobbyz wrote in post #6940271 (external link)
That is a big possibility, and would explain it all. When ever it didnt work, it was always with close subjects.
Thanks, Happy Holidays!
1,345 views & 0 likes for this thread, 6 members have posted to it.
1061 guests, 104 members online
