Thread started 24 Dec 2008 (Wednesday) 10:40
Canon 15mm f/2.8 Fisheye v. Canon 14mm f/2.8 L
timnosenzo
Dec 24, 2008 10:40 |  #1
Just in case anyone ever wondered what the difference in these two lenses might be, here's an example, taken from pretty much the same spot, both with the 5D.
14L
MIME changed to 'text/html' | Content warning: data
15 Fish
IMAGE: http://www.timnosenzo.com/photos/543661983_ijiDP-XL.jpg
j2photography
Dec 24, 2008 11:27 |  #2
i love the fisheye perspective. thank you for samples!!
FLICKR (external link)
https://photography-on-the.net/forum/showthre​ad.php?t=693311
Everything must go!!
x.pozhr
Gallery: 328 photos
May 22, 2009 13:01 as a reply to  @ j2photography's post |  #3
Wow..! The flag on on the ceiling is nowhere to be found, on the one taken with 14L.
Very interesting..!!
Gear List + Marketplace Feedback
kandyredcoi
May 22, 2009 13:03 |  #4
oh heck ya, that is awesome
did u use a tripod?
on the pics u can tell how much wider the FE is by looking at the boards on the left
on the 14L u can see 2
on the 15fe u can see 3.5
Unique Custom Watch Straps--> www.CTDesigns.us (external link)
shutterfiend
May 22, 2009 13:09 |  #5
pratman64 wrote in post #7970087 (external link)
The two photographs weren't shot on the same day. The displays on the columns are missing as well. Replaced by the green displays near the escalators.
https://photography-on-the.net …p=7812587&postc​ount=91776
superbad
May 22, 2009 15:03 |  #6
would you get the same result if you were using a XSI? (Anything other than a full frame)
5D III | 7D | 24-70 2.8L | 35 1.4L | 70-200 II 2.8L | 50 1.4 | 600EX-RT x3 | ST-E3-RT Transmitter
kandyredcoi
May 22, 2009 15:04 |  #7
a 14L would be 22.4L
a 15FE would be a 24FE
similar effect just not as wide
eth3rton
Gallery: 27 photos
May 22, 2009 15:05 |  #8
shutterfiend wrote in post #7970128 (external link)
Missed it at first but now that you said it the Flag would definitely be there... Glad you pointed that out.
rdenney
Rick "who is not suited for any one title" Denney
Joined Jun 2003
May 22, 2009 16:56 as a reply to  @ eth3rton's post |  #9
Notice that the kiosk in the center of the image is about the same size in both images, but the columns, doorways, and other items at the edges are smaller with the fisheye. A fisheye will project central subjects larger with respect to the field of view than will a rectilinear lens. In fact, the rectilinear lens is rectilinear because it magnifies the edges to a much greater extent than the center. That effect has more impact on their relative usefulness for me than the barrel distortion. One limitation on using ultrawides is that the central subject has to be really close to keep it from getting lost in the scene. The fisheye is more forgiving of that requirement.
Rick "who uses both" Denney
The List
Double ­ Negative
*sniffles*
May 22, 2009 17:14 |  #10
Very nice! I find they both have their place in the bag. On a FF sensor or with film, the 15mm is definitely fishy. On a 1.3x body it's not so bad and still wider than the 14mm.
As for a tripod in Grand Central, that's a no-no. Handheld only. Unless you clear it first, IIRC.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
JelleVerherstraeten
May 22, 2009 17:20 |  #11
I'm amazed about therence of the two!
Do you guys use them alot?
For me personal, I don't think I would use the 14mm very much....
-Jelle l Gear l Website (external link) l
Jannie
May 22, 2009 17:21 |  #12
Hoboy this is kind of a turn off for me, I hate curvy lines that can come from wide angle, I know fisheye creates this but when they were first invented they got used for everything and I got pretty sick of the whole idea. I've been thinking a lot about a 14mm for travel photography for like old castles, pyramids etc. but don't want the distortion. If anyone has some shots showing pretty strait forward shooting with a 14mm on a MKIII and is willing to post them I'd sure appreciate it.
I mean it's neat how much coverage you get and they are just another tool which have a place, I'm just having trouble with that. I will say that the 16-35II that I had was really quite good this way but it just might be the way you tilted down some with the 14mm that has me twisted.
Ms.Jannie
"When you come to a fork in the road, take it"!
1DMKIII, 85LII, 24-70L, 100-400L
rdenney
Joined Jun 2003
May 22, 2009 17:46 |  #13
Jannie wrote in post #7971354 (external link)
Both lenses are distortions of the three-dimensional world to make it fit onto two dimensions. Each distortion can be obvious and unrealistic, or not, depending on the subject and the composition. Thus, it's not really appropriate to use one scene to compare them, because it will end up looking like a special effect in one or both cases.
For example, is this a fisheye image?
IMAGE: http://www.rickdenney.com/images/juneau-sunset-2-lores.jpg
What about this one?
IMAGE: http://www.rickdenney.com/IMG_0560_cathedral_lores.jpg
Or this one?
IMAGE: http://www.rickdenney.com/images/st-helens-coldwater-ridge-l.jpg
All of these used extreme lenses, but their subjects and compositions are appropriate to keep their extreme projection from becoming a mere special effect.
Rick "Fisheye. Rectilinear (12mm on full frame). Fisheye" Denney
The List
joe ­ mama
May 22, 2009 18:35 |  #14
Killer FOV comparison. Thanks a lot!
--joe
www.josephjamesphotogr​aphy.com (external link)
www.pbase.com/joemama (external link)
kay188
May 22, 2009 18:40 |  #15
So these weren't shot on the same day?
I agree that I can see the difference of point of view, but It kind of gives the wrong idea since some items were removed from the area so it messes people up in a way.
I saw the 2 photographs and went "wtf? different perspective? i see more stairs.. yet the flag is missing, and the boards and signs on the sides arent there as well.."
Ricoh GRD4 | Canon 1Ds, 1D, 1D2, 1D2n| Canon XTi | Tokina 11-16 F/2.8 | Canon 16-35L I | Canon 24 F/2.8 | Canon 35 F/2 | Canon 50 F/1.8 I | Canon 135L | Sigma 24-70 EX DG Macro | Sigma 70-200 F/2.8 APO EX DG | Sigma 30 F/1.4 |Sigma 50 F/1.4 |Sigma & Kenko 1.4x TC| Canon 580EX II | Sigma EF-500 Super | 2x Vivitar 285HV | RF-602 Triggers |
19,939 views & 0 likes for this thread, 14 members have posted to it.
1050 guests, 115 members online
