Thread started 26 Dec 2008 (Friday) 15:11
Cleasing the AF screen 40D
roger767
Dec 26, 2008 15:11 |  #1
Does anybody know the best way to clean the AF screen. I don't mean the piece of removable plastic but the screen where the AF points are situated.
Ive tried blowing air but that hasn't helped. I think I need to go at it with senser cleaning products or send it somewhere for Professional cleaning.
www.rogerschooneveld.n​l (external link)
gjl711
Dec 26, 2008 15:23 |  #2
The autofocus sensor is located at the bottom of the camera and completely separate from the visible focus screen. You can see the sensor if you put the camera into manual sensor cleaning mode. There is nothing cleanable on it. The most that should be done is to give it a blast or two from a bulb blower.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
roger767
Dec 26, 2008 16:13 |  #3
When you pop open the Focusing screen compartment and look inside the compartment you can see a "sensor" with af points. On that sensor there is a lot of dust on it. Can I clean it with cmos sensor solution like visible dust or green clean.
gjl711
Dec 26, 2008 16:29 |  #4
I believe your seeing the bottom of the penta prism. if air is not enough to dislodge the dust you might try one of the sensor brushes, but I would be hesitant to use a wet cleaning system on it. If you want a bit more detail on whats up there, take a look at page 21 of the 40D white paper. It gives a pretty decent cross section of all the stuff up there.
http://www.usa.canon.c​om …40D_WhitePaper_​070817.pdf (external link)
::Gear::
roger767
Dec 26, 2008 23:56 |  #5
thank you for giving the pdf link, the part im trying to clean is the SI reflective plate. Im gonna try to clean it with sensor cleaning liquid. I hope it works
922 views & 0 likes for this thread, 2 members have posted to it.
Latest registered member is RawBytes
1532 guests, 160 members online
