Thread started 27 Dec 2008 (Saturday) 14:42
? with processing RAW in lightroom
RyanM
Dec 27, 2008 14:42 |  #1
After I process a photo in lightroom I save it as a .psd to preserve the photo. I then open it in photoshop and resize etc... to it.
When I want to save a .jpg of it it wont let me if I got to Save As, I have to go to Save for web.
Why wont it let me select .jpg when I go to Save As?
when i save it in save for web it takes out the exif data
thanks in advance
Canon 5DMKII w/grip // Canon 40D w/grip // 70-200mm f/2.8L IS // 16-35mm f/2.8L II // 50mm f/1.4 // 85mm f/1.8 // 430 EX ll
My Website (external link)
René ­ Damkot
Dec 27, 2008 14:57 |  #2
16bpc.
convert to 8bpc.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
RyanM
Dec 27, 2008 15:50 |  #3
that worked. thanks
what advantage is there to saving the .psd as 16bit vs. 8bit?
Sean
Dec 27, 2008 19:22 |  #4
RyanM wrote in post #6953537 (external link)
that worked. thanks
Canon 50D - 17-55mm F2.8 IS - 300mm F4L IS - 70-200mm F4L IS - 50mm F1.8 - 580EX II & 430EX - Full Gear Listing
Flickr (external link) - C&C Always welcome.
ibdb
TD's worst nightmare!
Location: Puyallup -- Don't worry. Nobody else can pronounce it either.
Dec 28, 2008 02:27 |  #5
that worked. thanks
There is some loss of information when converting a file from 16-bit to 8-bit. If you're continuing to do some heavy editing of a shot, it's best to leave as 16-bit for as long as possible. For most users, most of the time, the difference is likely to be small. There is a difference, however, and if the data is there, and your system can handle it, I figure you might as well take advantage of it.
-David
"David raises a good point. . ." -- CDS
"Once again, David Raises a good point! :lol:" The Wise and Powerful CDS
Gear List | Proof I Use The Gear In My Gear List (not necessarily proof I use it well) (external link)
René ­ Damkot
Dec 28, 2008 12:41 |  #6
Also, since you mention LR, you're probably using ProPhotoRGB. That should *only* be used in 16bpc.
When saving as a jpg, do the following:
  • Save the .psd
  • flatten image
  • convert to sRGB
  • convert to 8bpc
  • save as a jpg
More on ProPhotoRGB in the link from my sig.
809 views & 0 likes for this thread, 4 members have posted to it.
640 guests, 122 members online
