Thread started 27 Dec 2008 (Saturday) 17:08
Special handling precautions for the 85L
xenomorphic
"at least there are images..."
Dec 27, 2008 17:08 |  #1
Read in one of Canons little leaflets (those that kick around inside lens cases) a while back that "with certain lenses, like the 85L, it is recommended to always manually focus the lens to infinity before transporting the lens to protect it from vibration damage/knocks".
Thats quite a handling precaution - I mean, its a great piece of kit so if I ever get my hands on one I'll probably follow the advice - but are there many 85L owners out there who actually do this? Or have any experiences from NOT doing it?
Reviews:
ThinkTank Pro Speed Belt and Modular set
ThinkTank Urban Disguise 60
Gear list
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Dec 27, 2008 17:09 |  #2
I do that for any of the lenses I've owned which extend when focusing closer. Better the outer lens barrel getting knocked about rather than the inner cams...
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
Shuko
Dec 27, 2008 17:12 |  #3
I just keep the hood on always, problem solved. :)
www.miikajarvinen.fi (external link)
JeffreyG
Gallery: 42 photos
Dec 27, 2008 17:16 |  #4
I actually do keep the hood on so not really and issue.....yet strangely I do tend to move this lens to infinity before storage.
Another similar lens (in that the inner tube extends upon focussing) that I own is the 50/1.4, and I actually am careful to retract this lens when finished as it has a reputation for killing the finicky AF motor clutch when extended and taking a bump.
malla1962
Joined Jul 2004
Dec 27, 2008 17:48 as a reply to  @ JeffreyG's post |  #5
Thing is with that lens is the camera needs to be turned on to do so.
nuffi
Dec 27, 2008 18:48 |  #6
malla1962 wrote in post #6954096 (external link)
You can't manually focus that lens...?
blonde
Buck Naked Floozies
Dec 27, 2008 18:51 |  #7
nuffi wrote in post #6954380 (external link)
nope. the lens needs the camera to be on in order to focus so if the camera is off, you can not focus the lens.
Bill ­ Roberts
revolting peasant
Dec 27, 2008 19:00 |  #8
I think the thing is that if you need it to be as compact as possible when you put it in the case then you need to do this while the camera is switched on. Once it's off then moving the focus has no effect at all on the lens. You soon get used to this though.
BiLL
fr0natz
Dec 27, 2008 19:35 |  #9
Blonde: What? You make no sense. Manually focusing would do the same thing, wouldnt it? You focus the lens, not the camera.
Explain
40D, XT
Promaster (tamron) 17-50F2.8
Canon 70-200F4 L, 50 f1.8 nifty
430ex
JeffreyG
Gallery: 42 photos
Dec 27, 2008 19:41 |  #10
fr0natz wrote in post #6954601 (external link)
Explain
The 85L is focus by wire. Turning the focus ring only sends commands to adjust focus via the AF motor. If the camera is off or sleeping then turning the ring does nothing at all.
dshankar
Dec 27, 2008 19:51 as a reply to  @ JeffreyG's post |  #11
Are all lenses like this? Is there any place I could find out how each lens should be properly stored?
Jman13
Dec 27, 2008 19:53 |  #12
I do focus my 85L to infinity when storing. Yes, it's a pain, especially if I've already turned off the camera.
Jordan Steele - http://www.jsteelephot​os.com (external link) | https://www.admiringli​ght.com (external link)
Canon EOS R5 | R6 | TTArtisan 11mm Fisheye | Sigma 14-24mm f/2.8 | RF 24-105mm f/4L IS | Tamron 35mm f/1.4 | RF 35mm f/1.8 | RF 50mm f/1.8 | RF 85mm f/2 | RF 70-200mm f/2.8L IS | Sigma 135mm f/1.8
gary88
Dec 27, 2008 20:01 |  #13
I never knew the 85L was focus by wire. Makes sense though with all that glass.
Does that make other lenses rack and pinion focus? :p
www.garyhebdingjr.com (external link)|Flickr  (external link)IGear List|Alamy | (external link)Instagram: @garyhebding
JeffreyG
Gallery: 42 photos
Dec 27, 2008 20:11 |  #14
gary88 wrote in post #6954711 (external link)
Some of the older supertelephoto primes are also focus by wire. Check the Canon camera museum to see which.
I think the EF 85/1.2 L II is the only current model with focus by wire.
IMO focus by wire sucks, but the 85L is good enough in other areas that I put up with it.
TheGreatDivorce
Dec 27, 2008 20:27 |  #15
i don't usually do it, but every once in a while.
1,871 views & 0 likes for this thread, 14 members have posted to it.
1707 guests, 170 members online
