Thread started 27 Dec 2008 (Saturday) 22:03
550EX/40D flash exposure question
StarJack
Dec 27, 2008 22:03 |  #1
Look at these two snapshots and see if you can offer some guidance as to why the 550EX/40D combo would use a nice amount of flash indoors, and then a large amount of flash outdoors.
I don't use the flash often, I was just expecting a catch light type of flash in the outdoor shot. This is more like, "FREEZE, Police!" :lol:
I wouldn't have expected the 1 2/3 stop aperture difference (2.8 to 5.0) to cause the flash intensity difference in the outside shot? I'm just trying to learn why the camera would vary the flash so much between these two shots when left on it's own to determine exposure? :confused:
Regards,
Steve
40Dude6aedyk
Dec 27, 2008 22:11 |  #2
Outdoors, the background is dark and far away and only grandma is reflecting light back to the lens. Indoors, you have white walls reflecting light back to the lens.
What mode of exposure metering are you using? I like "Partial metering". I think the default is "Evaluative metering", see p. 92 of your 40D manual.
Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs
Curtis ­ N
Master Flasher
Dec 27, 2008 22:17 |  #3
It's all about the background.
The indoor shot has a close, white background to reflect the pre-flash, while the outdoor shot has a distant background with only the subject reflecting significant light from the pre-flash.
Even though Canon claims E-TTL II can find your subject and expose accordingly, I find that the presence of a close, bright background can affect the flash exposure dramatically.
StarJack
Dec 27, 2008 22:25 as a reply to  @ 40Dude6aedyk's post |  #4
I was in evaluative metering, no EC/FC. This is a shot moments later w/o flash at the same aperture. The shutter speed was only a a hair slower (1/13 to 1/15). (Trimming these since I know the other people would not want their pictures posted.)
All I was looking for was a soft catch light, any suggestions on the best settings to get that under these conditions when time is short? Think spot metering would've helped given the back round then?
Many thanks for the comment(s)!
Regards,
Steve
40Dude6aedyk
Dec 27, 2008 22:33 |  #5
In this situation, I would just look at the pic in the LCD, then make a quick FEC adjustment and retake. Repeat until satisfied. I think I could do 3 shots in 10 seconds. I've left my 40D in "partial metering" mode since I first bought it. I shoot mostly sports and people where I'm mostly interested in what's going on near the center of the field of view.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 27, 2008 22:35 |  #6
Something you can try:
After locking focus, recompose so that the persons face is dead center (still with the shutter half-pressed) and press the * button for FEL. Then immediately recompose and complete the shot.
Bob
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 27, 2008 22:38 |  #7
And wow ... everyone sure stood still for you to get such a good capture at 1/15s :)
For this case I probably would have used flash with the camera in Manual at 1/60s to 1/100s and f/5. But my kids don't stay still ... so what do I know :)
Bob
StarJack
Dec 27, 2008 23:14 as a reply to  @ Bob_A's post |  #8
Curtis, going to read your links! :cool:
40Dude I hear you and Curtis both on the background. Time wise, I'm sure I can't match your chimp and adjust speed. I can't see the LCD well or read the menu with the glasses on, can't see worth a darn more than 10 feet away without them, absolutely can't stand bifocals or the blended lenses. (Getting older fast!) I'll try the more restricted metering modes in the near future.
Bob, I'll try the face centering, FEL advice as well. I had a few shots that were blurry. I was thinking (after the fact of course :rolleyes:) that I should have set the ISO up to 200 and/or opened up another stop on the aperture. I just have started using M in ambient conditions, haven't even really tried using flash in M mode yet since I'm obviously still in the early learning curve with flash in Av/Tv, but I will.
I really appreciate the feedback! :)
Regards,
Steve
40Dude6aedyk
Dec 27, 2008 23:30 |  #9
I have DefinityII progressive lenses for my eyeglasses. Have you seen them? They are quite different than other progressive lenses. Check with your eye doctor next time you go in.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 28, 2008 00:05 |  #10
StarJack wrote in post #6955676 (external link)
Curtis is the Master of Flash (for some reason I think of something else when I hear the term "Master Flasher") ... he always gives solid advice :)
Bob
Curtis ­ N
Master Flasher
Dec 28, 2008 00:13 |  #11
Hopefully you have your camera's diopter adjusted for your vision. You should be able to adjust the FEC without removing your eye from the viewfinder.
StarJack
Dec 28, 2008 00:43 |  #12
Curtis N wrote in post #6955930 (external link)
Yes I do, no problem really seeing through the viewfinder. And I was picturing using the FEC ON the 550EX, not using the EC on the Quick Control Dial on the 40D. From page 36 of the 550EX manual, "You can also use flash exposure compensation in combination with normal exposure compensation (to control the background's exposure level) in a flash picture." So I was thinking FEC on the 550 is dialing up/down the flash power, and the QCD is altering exposure for the scene, based on what metering mode I'm in.
So am I misreading the 550 manual, or misunderstanding what 40Dude was meaning, or both!?
Regards,
Steve
40Dude6aedyk
Dec 28, 2008 07:15 as a reply to  @ StarJack's post |  #13
I'd adjust FEC on the camera body. Click on the ISO/FEC button with your right index finger (top right of camera), then spin the thumbwheel with your thumb. No need to take your eye off the viewfinder. However, to look at the pic on the LCD you do need to take your eye off the viewfinder. I have pic review set to 4 seconds, so the pic is on the LCD for that amount of time.
PS: After pressing the ISO/FEC button, if you don't want to change the ISO, don't spin the fingerwheel. :)
StarJack
Dec 28, 2008 10:32 as a reply to  @ 40Dude6aedyk's post |  #14
OK, thanks! And in relation to being faster/easier I certainly understand. But in relation to my OP, why I wouldn't just adjust the FEC on the flash unit itself, if I'm happy with the scene exposure overall? Let's say I'm in Av, if I use the QCD to alter EC then I'm changing my shutter speed. But if I use FEC on the 550 then I'm just altering the amount of flash being used w/o out changing the shutter speed?
Regards,
Steve
Curtis ­ N
Master Flasher
Dec 28, 2008 10:36 |  #15
You can adjust FEC on the flash unit or with the camera. Your choice. I recommended the camera method for you because you can use the viewfinder with its diopter adjustment for your eyes.
Either way, it's different than EC. It's adjusting the flash power. Re-read your camera's instruction manual on Flash Exposure Compensation.
2,441 views & 0 likes for this thread, 5 members have posted to it.
1065 guests, 115 members online
